Front end woes.......
Old Oct 5, 2004 | 10:35 PM
'02 Style's Avatar
This past weekend, I started noticing a very distinct vibration in my front passenger wheel. Thinking that I had busted a belt in the tire, I replaced the front tires, but the problem persists. You don't notice the vibration below about 40 mph but at highway speeds, it is pretty bad. I have however noticed that when turning to the right, the problem subsides, regardless of speed. As soon as the steering wheel is straightened, the problem returns. Any ideas what this could be??? Tie rod? Possibly a control arm? Please help!
Old Oct 5, 2004 | 11:15 PM
aussie983's Avatar
check your alignment
Old Oct 6, 2004 | 06:31 AM
THill5thGen's Avatar
check your lugs, wheel might be loose
Old Oct 6, 2004 | 06:36 AM
filtor1's Avatar
Wheel baring. From the sound of it anyway.
Old Oct 6, 2004 | 06:54 AM
rzayas144's Avatar
Baring my guess too.
Old Oct 6, 2004 | 06:59 AM
Ryans Maxima's Avatar
Originally Posted by rzayas144
Baring my guess too
Bearing???
Old Oct 6, 2004 | 07:37 AM
'02 Style's Avatar
I know that the lugs are tight, and my from end could use an alignment, but it is not bad at all. So I guess that the wheel bearing thing could be the problem. Any ideas on what it should cost to have it fixed, and what would be involved?
Old Oct 6, 2004 | 07:52 AM
rzayas144's Avatar
mine was like 450 to 500 i think.
Old Oct 6, 2004 | 07:54 AM
Puppetmaster's Avatar
DAYAM... that's a lot.... my front tires have started to vibrate (causing the steering wheel to vibrate too) when I go over 60 mph... is this a bearing issue too?
Or does this have something to do with me rotating the tires?
Old Oct 6, 2004 | 07:57 AM
96max5sp's Avatar
Mine was 260 installed at pep boys. It was $60 for the part and the rest was labor.
Old Oct 6, 2004 | 08:01 AM
rzayas144's Avatar
mine would shake untill i hit 80 and then it would stop.
Old Oct 6, 2004 | 08:02 AM
So maybe I should driver over 80 more....
Old Oct 6, 2004 | 08:03 AM
rzayas144's Avatar
Yea try it
Old Oct 6, 2004 | 08:59 AM
'02 Style's Avatar
rzayas144,
Sounds like you have had a similar problem. How did you know for sure that it was a bearing, and not some other problem? Running a little low on cash right now, and don't wanna spend a lot on diagnostics. Thanks!
Old Oct 6, 2004 | 09:57 AM
wngan9447's Avatar
Chicken Feet Croo!
If it vibrates between 40-60 and when you hit 80 it goes away.. balance your tires.. this would be my guess
Old Oct 6, 2004 | 04:14 PM
JustTry's Avatar
Jack up the front end.
Grab you wheel on the top and bottom and push/lift. If there's any play (up and down) then you have a bad bearing.
If it just started, then there's a chance that only the bearing is bad. With time it'll ruin the hub. You could do it yourself and have a machine shop to press the bearing for you.
Old Oct 6, 2004 | 07:35 PM
irish44j's Avatar
retired moderator
Also, with the car jacked up put your left hand on one of the coils of the spring. with your right, spin the wheel. If the bearing is bad, you will be able to feel it through the spring, as if the wheel is rotating with sand inside of it....
Old Oct 6, 2004 | 09:11 PM
SEturner's Avatar
Don't forget, wheel bearings ARE covered under the 5/60 powertrain warranty.
I have had one replaced, and from the labor (1.7 hrs) and part ($90), it would have been a $200 job at the dealership. I have another one going out now. It does shake steering wheel at highway speeds (it is on front) and sounds much like unbalanced tire. I had tires rotated and balanced today, with no change to symptoms. The noise is loudest at 20 MPH and quieter at 60MPH. It sounds like a loud roar, especially when braking down through 20 MPH (It sounds same if I take foot off brake pedal).
Old Oct 7, 2004 | 08:46 AM
'02 Style's Avatar
Jacked up the front end this morning, no play in the wheel, and while holding the strut, didn't feel like sand in there. Any other ideas?
Old Oct 7, 2004 | 08:58 AM
JustTry's Avatar
If there's the bearing play, it should be an unbalanced tire.
Old May 13, 2005 | 07:59 PM
okay's Avatar
i think my wheel bearing is out on my passenger side i have 80k miles but i have the extended powertrain warranty from nissan (silver security plus plan) will they cover the wheel bearing under warranty?
thanks
Old May 13, 2005 | 08:15 PM
Army of Maxima's Avatar
Looking for a few good Maximas
wheel bearing, alignment, or even quite possibly a bad hub...
Old May 13, 2005 | 08:22 PM
upstatemax's Avatar
I had a vibration in my rear tires and I had the bearings replaced and it stopped. Now I am getting it in the front end so I think I am going to have new ones thrown in the front end as well.
Old May 13, 2005 | 08:24 PM
upstatemax's Avatar
Even if YOU dont feel bearing play it can still cause the vibration. when my rears were replaced, I could not feel any play, yet they were bad and the vibration stopped after having them replaced.
Old May 14, 2005 | 09:42 AM
Wow, I asked that question 7 months ago... the vibration I had actually went away after I rotated my tires... guess it was just uneven tread wear...
AcuraLegend
Oct 17, 2016 08:47 PM
AcuraLegend
Sep 22, 2015 04:22 PM
GregL65
Sep 5, 2015 09:37 PM
jfl330
Sep 4, 2015 01:44 PM
