Rear sway bar installation problem
Old Oct 6, 2004 | 05:27 PM
Lontar1's Avatar
Puerto Rico-Maxima Lover
I bought the knock off RSB from ebay. Now the bar is to short (not wide enough to be insatall What to do. Can someone tell me how to add a picture and will upload one. Thanks
Old Oct 6, 2004 | 05:30 PM
Larrio's Avatar
The Definitive AE Master
well, first off... if its a knock off you could have possibly got ripped off. Second, just sign up on www.cardomain.com and upload a picture and copy and paste the link in here by right clicking on the picture properties
Old Oct 6, 2004 | 05:39 PM
Tek-Niq's Avatar
my rear view mirrors flap like a f-ing bird
in order to post a pic you have to have a place of host like "cardomain" put the pic there get the address by right click on the pic then go to property. put it here by adding " [img], [/img] " to the beg. and end of the address. good luck
Old Oct 6, 2004 | 06:01 PM
Lontar1's Avatar
The sway bar is like one inch short.. is that normal or does it has to be right on.... it is s stupid question but may =be there a way to fix this....
Old Oct 6, 2004 | 06:05 PM
Tek-Niq's Avatar
Hell no, if its too short you will need to be a real good metal guy to extend that bar and keep it with in specs. I think your screwed. you sure you got the right year for your car
Old Oct 6, 2004 | 06:10 PM
thomwin's Avatar
sounds like they sent you one for the wrong model, maybe they sent you an Altima one or something. Do you have a packing slip that mentions the model anywhere? did the sell offer a return policy?
Old Oct 6, 2004 | 06:13 PM
Larrio's Avatar
the altimas have a rear sway bar with independent rear suspension. Couldn't be another model cause the maxima sway bars fit 95-03
and btw, what is it a knock off of? stillen, etc
Old Oct 6, 2004 | 06:19 PM
thomwin's Avatar
I assume you got this one and it appears to be the only one they make so yeah it couldnt be for another model. I was told it's a stillen knock-off in a differnt thread when I inquired about it. I bought the cattman/progress instead.
Old Oct 6, 2004 | 06:46 PM
Lontar1's Avatar
http://cgi.ebay.com/ebaymotors/ws/eB...tem=7924607241
So am I f$^%$d..or what......
Old Oct 6, 2004 | 06:59 PM
thomwin's Avatar
Seller has good feedback, maybe he'll send you a new one, but he's also a "power seller" usually the worst with communication.
Before that, why not measure it's, and find someone on the forums with the same unit (or a stillen) who can measure theirs and do some mathematical comparisons just to make sure.
Old Oct 6, 2004 | 07:05 PM
Lontar1's Avatar
http://www.topspeedauto.com
This is the website form the dealer.....
Old Oct 6, 2004 | 07:09 PM
thomwin's Avatar
Make sure you are trying to mount the brackes to the outside of the bar. if you try mounting on the inside, that would make up the inch gap.
Old Oct 6, 2004 | 07:19 PM
Lontar1's Avatar
Man right now am so pissed that can't think... Out means....... this is my page you can see the sway bar at the end.........
http://www.cardomain.com/id/lontar
Old Oct 6, 2004 | 07:22 PM
Lontar1's Avatar
Old Oct 6, 2004 | 07:23 PM
Lontar1's Avatar
http://memimage.cardomain.net/member.../335521_12.jpg
Old Oct 6, 2004 | 07:25 PM
thomwin's Avatar
Here's a good read also...
Old Oct 6, 2004 | 07:30 PM
thomwin's Avatar
Here's the actual stillen item the brackets are on the 'outside' of the U shaped bar.
That may be how you have it already. Just trying to rule out all the small stuff.
Old Oct 6, 2004 | 07:35 PM
Lontar1's Avatar
http://vqpower.tripod.com/rsb.htm
I just follow this... but I can't put it like on the inside.....
Old Oct 6, 2004 | 07:37 PM
Progress's Avatar
It's business time.
When you say too short, do you mean the ends of the bar don't reach the trailing arms on both sides of the car? It's kind of hard to tell from the pictures.
Also, did the suspension change from independent to rear axle sometime between '89 and '03?
Old Oct 6, 2004 | 07:38 PM
thomwin's Avatar
Sounds like you are doing everything right. probably time to call the seller. at least they are a U.S. store that might have a good return policy.
Old Oct 6, 2004 | 07:39 PM
Lontar1's Avatar
I just looked at the pictures again... does it means that you aactaully use on bolt to hold the sway bar????????
Old Oct 6, 2004 | 07:42 PM
thomwin's Avatar
one bolt per bracket.
Old Oct 6, 2004 | 08:03 PM
Larrio's Avatar
yea, of course you use bolts to hold the sway bar on! There should be two holes on each flat side of the bar, four total. 2 bolts for each bracket, two brackets to a side so four bolts each side, 8 bolts total.
the stillen unit also comes with 16 washers, 8 nylock nuts, and one spacer to space out the e-brake cable
Old Oct 6, 2004 | 08:55 PM
Lontar1's Avatar
Done... I have to thank you all specially thomwin for openning my eyes. I was trying to put the sway bar to the inside not the outside..... Dumm my bad....... Thanks again very much...... I'll take some pictures and will post them tomorrow..
How do I add a picture to my signature...?????
Old Oct 6, 2004 | 09:15 PM
Larrio's Avatar
profile --> settings and options --> edit signature --> [img]link[/img]
Old Oct 6, 2004 | 09:49 PM
Lontar1's Avatar
this is a test
Old Oct 6, 2004 | 09:54 PM
Lontar1's Avatar
I did it but didn't work.... whats wrong
Old Oct 7, 2004 | 03:18 PM
Tek-Niq's Avatar
this is a test
there real small tough got better one
Old Oct 7, 2004 | 07:33 PM
Lontar1's Avatar
" [img] http://memimage.cardomain.net/member.../335521_13.jpg ,[/img] "
Old Oct 7, 2004 | 08:23 PM
Progress's Avatar
It's business time.
Dude, to post a picture do this:
Open it up, right click, click properties, copy the link and paste it in your post, the right before it w/o spaces or commas put in "[IMG]" at the front and "[/IMG]" at the end.
GL
Old Oct 7, 2004 | 08:30 PM
Lontar1's Avatar
"[IMG]" http://memimage.cardomain.net/member_img_a/335521_13_full.jpg"[/IMG]"
Old Oct 7, 2004 | 08:33 PM
Lontar1's Avatar
Well there has to be something wrong. I have everything you have told and nothing... so I give up....
Old Oct 7, 2004 | 08:37 PM
Lontar1's Avatar
test
Old Oct 7, 2004 | 08:39 PM
Lontar1's Avatar
it worked thanks
Old Oct 8, 2004 | 04:51 AM
Lontar1's Avatar
anothr test I have to reuce my signaature
homeyclaus
Sep 3, 2015 06:15 PM
Dasmith
Aug 25, 2015 10:15 PM
Maxboy23
Aug 20, 2015 09:33 AM
MaxStock
Aug 14, 2015 10:03 PM
jerrod99_se-l
Aug 10, 2015 12:07 AM
