What do you think it is?
Old Oct 7, 2004 | 04:00 PM
Manaz101's Avatar
As of recently i've noticed the car doesn't start on the first crank. Before i would flip the switch and on the first shot it would start, now it seems like it takes a couple of cranks by the starter to start the car. I've also had some times when i've had to turn the key back to the off position and turn it once more. I'm suspecting it either is the battery (which has died on me once & is factory) or maybe the ignition coil? I also thought i might be the key, not sending the signal to the ignition switch.....but i don't think that anymore.
So what do you guys suggest?
Old Oct 7, 2004 | 05:14 PM
midnightmax01's Avatar
could be either the battery or maybe even the crank position sensor and the camshaft position sensor, there was actually a recall to replace them just to let ya know as long is it is a 3.5
Old Oct 7, 2004 | 06:15 PM
Manaz101's Avatar
Yea, i got that done earlier this year. So i don't think it's that, unless that one is messing up as well.
Old Oct 7, 2004 | 07:30 PM
irish44j's Avatar
retired moderator
bad starter maybe?
Old Oct 7, 2004 | 07:45 PM
ZIPPIN's Avatar
Mauja He Mauja
how many seconds do you crank her?
Old Oct 8, 2004 | 08:47 PM
Manaz101's Avatar
Not too long -ZIPPIN-, just noticing that it's not going on the first turn over. If this goes on or gets worst i'll look into a new battery as that's that cheapest.
Hope it's not the starter irish.......that would suck replacing.
Old Oct 8, 2004 | 09:21 PM
SEmy2K2go's Avatar
Go BUCKS!!!
Have you taken the car in and given Nissan the chance to duplicate the issue?
Old Oct 8, 2004 | 10:52 PM
mad2kmax's Avatar
If it was the battery, then the first failed startup would sound slow, like the starter just didn't want to turn over. If it's trying to turn over at the same speed as normal but just doesn't, it could be any number of things. I wouldn't say coils as the 3.5 max's have good coils and I've never really heard of them failing. What kind of gas do you use? My '00 max was having the same problem until I replaced faulty coils AND my fuel filter. The filter was nasty and probably should have been changed long ago. Maybe you have a clogged fuel filter, I dunno
Old Oct 8, 2004 | 11:01 PM
MaximaPolak's Avatar
There have been cases where they put in broken ones also.
Old Oct 9, 2004 | 06:43 AM
Manaz101's Avatar
Yea, i don't know guys.....i use 93 octane gas, so i don't think it's gas. I honestly think it's the "crank power". Plus i don't think it's a big enough issue for me to take it to Nissan, knowing how they are they'll probably try to stick for me for some big $$$ when it might be something simple. Thanks for suggestions guys, appreciate it!
Old Oct 17, 2004 | 05:03 PM
Manaz101's Avatar
It was the battery! Cheap nissan battery left me stranded yesterday. Car won't start, luckily i was in a shopping plaza where there was a Pepboys where i could get a jump. I headed straight to a yellowtop and once in the car started up perfectly. On the way to buy the battery, the stupid car died again in the parking lot of where i was going to buy the yellowtop. I actually had to push the car into a space. Now the car feels smoother and fires right up on the first crank. If you don't have one yet, get one. They're worth every penny.
