will the grill-tech grill fit even if you have the MT lip on ??
Old Oct 11, 2004 | 07:21 AM
Qmax03
I just got the mt lip and was wondering if the grill tech grill will fit too ?
Old Oct 11, 2004 | 09:07 AM
thomasd cook's Avatar
I have a 2000 and I have a lip. Yes, I was able to get the grill back in the lower valence.
Old Oct 11, 2004 | 03:13 PM
WildmanAL's Avatar
I have the stillen lip and with my first grille tech it was extremely tight and wasn't all the way in there. I tried shaving the sides of the grille, but I ended up destroying it. I ended up buying another set from another org member. This which were not even going to be close into fitting. I pulled the protectant material off the bottom part of the grill and took a dremel and cut a row off of the metal screen. I had to section the protectant outer boarder a little on the sides since I made the screen shorter. It's looks like I never did anything to it and it fits perfectly. You won't beable to fit the grille tech in perfectly because how the lip sits on the front.
Old Oct 12, 2004 | 02:09 AM
Triple8Sol's Avatar
I miss the .org!
So basically the answer is, "NO" they won't fit, unless you take quite a bit of time to modify them and make them fit.
Old Oct 12, 2004 | 05:29 AM
WildmanAL's Avatar
Well yes modification is required, but it isn't hard by any means. Just becareful not to cut off too much and keep with the contour of the metal screen.
REDinLV
Aug 15, 2024 12:30 AM
Apr 16, 2020 05:15 AM
Nv2dmaxmd
Oct 19, 2015 05:37 PM
Garrettz459
Sep 28, 2015 02:50 PM
ricky7780
Sep 24, 2015 06:50 PM
