paint chips and transmission slippage
Old Oct 12, 2004 | 09:22 AM
GBAUER's Avatar
I have an '03 SE with about 80k on it (OK, I drive a lot). The only mods I've done is an Injen intake and Micheline Pilot Sport tires (STRONGLY recommend them. My Max will hold corners like a Porsche now! Well worth the Deneros). I only have two complaints; first off, Nissan needs to get a new paint supplier! I've already had the front repainted, but I think the problem isn't the paint, it's the primer or the coating on the steel below 'cause even my new stuff chips (had a great friend who happened to own a kick-*** body shop in Gaithersburg, MD who was known for his work on several show cars). The other complaint I have is tranny slip. I want it to go, but damnit if it don't stop going around 40 and then at 80! I would've killed a Boxter all around if it weren't for the slippage! I still got him at 130, though... he wasn't very happy either!
Any recommendations on the slippage? I've given up on the paint and bought a bra (doesn't look toooo bad...)
Old Oct 12, 2004 | 09:41 AM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
have you done a tranny oil flush or at least a drain and refill yet?
Old Oct 12, 2004 | 09:42 AM
GBAUER's Avatar
ya, had it flushed and filled. Still had the same problem. I'm thinking it needs heavier tranny fluid
Old Oct 12, 2004 | 10:04 AM
Zero Deuce SE's Avatar
Did you ask your friend about the paint/primer? If he used a different paint than Nissan I would not blame Nissan for having defective paint. I believe that if the primer coat is bad, the whole paint job will eventually fade away in short order. And you surely do drive a lot.
Old Oct 12, 2004 | 10:53 AM
GBAUER's Avatar
He used the Nissan paint. I was looking at http://www.nhtsa.dot.gov and saw a few complaints about the paint on this. All in all, I've thrown up my hands on that front. Still wondering about the tranny slippage, though. I saw a few notes about it in other years, but nothing on the '03 with automatics (I should've bought the SE w/ the manual!).
The milage is 'cause I drive about 40k a year for work. I'm a manufacturer's rep, so I'm limited to the mods I can do. Don't want to flash too much bling in front of the guys buying stuff from me or else they may not think I need the cash!
Old Oct 12, 2004 | 11:05 AM
kcowden's Avatar
Is it slippin or hesitating? There are TSB's out for hesitation and a tranny that "abnormaly shifts" if you have a fax I'll send you the tranny TSB. Although with 80k on it it may be out of warranty.
Old Oct 12, 2004 | 11:14 AM
GBAUER's Avatar
It doesn't want to shift out of first or second when under heavy accelleration. I guess it would be considered hesitation. I'll ask the dealer about the TSB if you can tell me the number. The dealer I use is pretty honest and will work with me if I bark loud enough.
Old Oct 12, 2004 | 12:32 PM
kcowden's Avatar
The TSB is NTB04-035 dated March 10, 2004. For a copy go to the technical service bulletin thread. It's in there. Bark loud and let me know what the outcome is.
Old Jun 28, 2006 | 07:59 PM
irish44j's Avatar
retired moderator
didn't look that way at the autocross...
Old Jun 28, 2006 | 09:15 PM
Gapp's Avatar
HAHAHA! Backindanoobiedaze!
Old Jun 28, 2006 | 10:38 PM
SoonerFan's Avatar
Cletus
wow!!!
holy grave digging!!!
REDinLV
Aug 15, 2024 12:30 AM
Apr 16, 2020 05:15 AM
Pied
Sep 26, 2015 03:29 PM
