Climate Control Swap
Old Oct 13, 2004 | 02:53 PM
ISELKARS2's Avatar
Anybody Swap A Manual Climate Control For An Automatic One? Any Problems?
Old Oct 13, 2004 | 03:40 PM
StillenMax80x20's Avatar
no, idea, but.... you might need to run the power for the display through the factory dimmer, not hard, PM me for write up. Although, only those with manula air would know whether or not there are lights, it's likely you could just plug and play, hardwire may be necessary though
good luck
Old Oct 13, 2004 | 04:53 PM
MIXXMAX's Avatar
May be posssible but very difficult. It's not plug-n-play. Auto has totally different wiring and sensors than manual.
Old Oct 13, 2004 | 04:56 PM
Tek-Niq's Avatar
my rear view mirrors flap like a f-ing bird
I'm also interested in this mod. anyone?
Old Oct 13, 2004 | 05:49 PM
SoonerFan's Avatar
Cletus
its more money and labour then its worth.
you will need-
climate control unit
2 sensors (interior and exterior temp)
new wiring (ALOT)
Old Oct 13, 2004 | 05:57 PM
Tek-Niq's Avatar
you will need-
new wiring (ALOT)
Yea If I was to do it It would only be something only I know its there because who the hell says "hey you got a auto climate control?" its only a cool DIY mod, and I kinda miss it since I had a 96 infiniti I30 that had it.
thanx anyway though.
Old Oct 14, 2004 | 06:27 AM
custommaximaSE's Avatar
you will need-
new wiring (ALOT)
And you need an PRO to do it.We did not say you can't do it,because its possible.
Old Oct 14, 2004 | 07:53 AM
icelandmaxima's Avatar
Maxima Fanatic
Not worth it, also more things could go wrong with the digital.
Old Oct 14, 2004 | 08:05 AM
Gennady7's Avatar
i think manual is better since its just pressing a button.
i wanted to do auto, bought the auto climate controller, installed it and the wires did not fit. Basically 2 pairs of wires did fit but one wire harness had no where to go into so the unit did not power.
Old Oct 14, 2004 | 08:14 AM
BlackBIRDVQ's Avatar
drag racing is for wussies
I analyzed the 01 FSM for climate controll, digital vs manual. There are quite a bit more wires going to the auto climate, you would need a whole dashboard wire harness, 2 sensors- photo sensor and incabin temp sensors, then the ambient temp sensor also if you would like to know the temp outside the car. I had a good deal on a auto climate controll head and tried it. Plugs are diff, even after modiffying the plugs and switchn the pins out the climate controll didn't work right. So I went back to manual.
Old Oct 15, 2004 | 08:13 AM
ISELKARS2's Avatar
Thanx for the info and the comments-I guess I'll hold off and do other mods!!
mikeg75
Nov 30, 2015 05:12 PM
Max139617
Sep 29, 2015 06:44 PM
Bonka
Sep 14, 2015 11:18 PM
EdRomo86
Sep 12, 2015 07:49 PM
