Cleaning your the engine... (split)
Old Apr 10, 2001 | 08:09 AM
humaras's Avatar
you hose down your engine?
Lovesick,
I read your post about washing the engine, and I have a question: Do you cover anything up in your max such as the battery, alternator, or anything else before you degrease and spray your engine with the garden hose? I have been contemplating cleaning my engine for a long time now with all the salt and etc...but haven't had the nerve because I am afraid of shorting something out.
If you can comment on this, that would be greatly appreciated. what is your technique by the way? do you hose the engine all over? top to bottom?
appreciate the help.
Brian
Originally posted by LoveSick
Engine cleaning
I think Maxima gets dirty engine pretty easy. The only way to keep it clean is to clean it as often as you can, this way you will lower the chance of buildups that cannot be get rid of.
The way to clean it is easy, you could use a garden hose and rinse it with high pressure, then apply some soap at the paint area and the engine area.
If you engine already has tough to remove buildups, then rinse it with high pressure washer and spray degreaser on it. Then rinse if off with high pressure washer again. After this, you might want to apply some wax to the painted area.
Old Apr 13, 2001 | 07:28 AM
Y2KevSE's Avatar
Rice Boy in Denial =)
Bump...
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
fx4five
Oct 1, 2015 04:58 AM
sliptap
Sep 30, 2015 05:57 AM
