Rattle when I start....?
Old Oct 20, 2004 | 05:38 AM
Roadblock's Avatar
I cant figure out if it is the intake or something else. Anyone else have a similar problem? I sounds like an aluminum can kinda tappin a fan or something. It doesnt happen EVERY time, and the sound changes the times that it does.
Old Oct 20, 2004 | 05:40 AM
Qmax03
its most likely the heat shield, im having mine replaced under warrenty
Old Oct 20, 2004 | 06:46 AM
2002 Maxima SE's Avatar
Pretty common amoungst the 2002 and 2003 gang unfortunately. Its the timing chain sprocket. There is a TSB out where they will replace the sprocket, but it's up to you to trust the dealership to remove a large portion of your engine to get to it (depending on which side). Most say that it will do no damage or little damage to the engine...just a loose timing chain tightening up.
Old Oct 20, 2004 | 06:59 AM
NmexMAX's Avatar
dot dot dot ...
Had the same problem w/ my 95, but the 02+ have the CVT sprockets on the cam sprockets. Even though the tensioner is below all that, seems like a big job. And even after my 95 tensioner was replaced, it still did it to a certain degree .
user 11122324
42
Jul 18, 2022 03:35 PM
lrb6805
Sep 17, 2015 04:49 PM
jerrod99_se-l
Sep 16, 2015 02:39 AM
thenewguyy
Sep 12, 2015 11:12 AM
NissanNismoZ
Sep 12, 2015 07:30 AM
