spark plug decision...
Old Oct 21, 2004 | 07:08 PM
panda_1's Avatar
what kind of plugs are the best for a NA 2k 5-speed
Old Oct 21, 2004 | 07:39 PM
spirilis's Avatar
anything made by NGK. Do yourself a favor, DO NOT BUY ANY OTHER BRAND of spark plugs. NGKs work best.
They go from the expensive (Iridium, and OEM platinums) to the cheap (NGK V-Power copper).
OEMs, as mentioned above, are NGK double-tipped Platinum spark plugs. They are around $10-12/piece I think.
Iridiums I'm not sure, they're expensive though. V-Power Coppers are probably less than $2/piece, but are only supposed to last ~30K miles or so. In my experience, since I use V-Power copper, after 30K the gap rises from the stock setting of .044" to somewhere in-between .045" and .051". Changing them out didn't do a whole lot, and I probably could have just regapped the old ones and reused them for another 15-30K.
Platinum plugs are supposed to last no longer than 105K miles.
Old Oct 21, 2004 | 07:44 PM
panda_1's Avatar
im most likely just gonna et the oem plats, another orger told me something about some ngk-r's is this true ne diff?
Old Oct 21, 2004 | 07:52 PM
spirilis's Avatar
"ngk-r"? never heard of it. AFAIK, there's not a whole lot of performance difference in the spark plugs here... Platinums last a while, Iridiums are supposed to last a while, coppers don't last a while. Coppers generally reduce pinging in extreme scenarios (boost, nitrous, etc.) if I'm not mistaken about past readings, but I don't think their performance is much different otherwise.
Old Oct 21, 2004 | 07:57 PM
Tek-Niq's Avatar
my rear view mirrors flap like a f-ing bird
I got the NGk densos still in the box I'm afraid to put them in. thinking is not going to work.
*****denso iridiums
Old Oct 21, 2004 | 08:09 PM
panda_1's Avatar
how can the spark plugs not work? another thing how much are we supposed to torque the plugs?
Old Oct 21, 2004 | 08:12 PM
Raf2kMax's Avatar
www.sparkplugs.com have the iridium and double platinums for the SAME PRICE!! under 12 bucks each
Old Oct 21, 2004 | 08:28 PM
panda_1's Avatar
how much does nissan charge?
Old Oct 22, 2004 | 04:05 AM
Tek-Niq's Avatar
I didn't mean "not work" genaraly just not work as in the car won't respond right or something. I saw some theads that the car gets kinda sluggish and you know not normal ****.
Old Oct 22, 2004 | 04:24 AM
panda_1's Avatar
regardless im gonna go with the factory plugs
Old Oct 22, 2004 | 04:34 AM
spirilis's Avatar
Torque them no higher than ~18 ft/lbs... the spark plugs should have directions on them (OEM Nissans might not, not sure).
Definitely use a torque wrench to tighten them for best results.
magiconthetire
Oct 26, 2015 09:03 PM
Need help
23
Oct 2, 2015 08:56 AM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
