Removing radio bracket screws - How dio you guys do it?
Old Oct 23, 2004 | 12:18 PM
blackmaxgic's Avatar
I'm tried replacing my radio today and had no luck removing those practically welded in radio bracket screws. I'm interested in how others have removed these without breaking screws and screwdrivers.
Thanks for the advice
Old Oct 23, 2004 | 12:27 PM
Lytheum's Avatar
you need an impact driver of some sort...atleast its the easiest way. my friend got one out with a drill, but i had to use and impact driver for the rest.
Old Oct 23, 2004 | 01:53 PM
brettb's Avatar
O'rly
I used a high powered drill on some, a 12" long screwdriver and a 2" screwdriver. It was a two person job (one to hold and one to unscrew). They are very hard to take off. Good luck.
Old Oct 23, 2004 | 02:25 PM
mrmj1218's Avatar
Yeah the screws have threadlock on them. My father and I drilled them out of my headunit. The dealership will sale you another set of brackets for $20 each.
Old Oct 23, 2004 | 03:06 PM
speye022's Avatar
take a ice pick or something with a tip that will fit the center of the screw's head. Use a hammer to hit the ice pick as if you were nailing the ice pick into the center of the screw's head. Now the screw should unscrew without too much effort using a screwdriver and pressing down on it so you don't strip the screw. If the screw doesn't move, repeat the "nailing" but harder. It's really easy...just don't strip those screws if you plan on re-using them.
Old Oct 23, 2004 | 03:44 PM
ZIPPIN's Avatar
Mauja He Mauja
i used a large screw driver and steady torque. you can spray it with wd-40. that may help loosen it a little
Old Oct 24, 2004 | 06:58 AM
Triple8Sol's Avatar
I miss the .org!
Weird...mine came out easily...
Old Oct 24, 2004 | 07:01 AM
SoonerFan's Avatar
Cletus
mine came out too. granted it took some muscle but they came out. i guess i just have a strong wrist.
Old Oct 24, 2004 | 08:18 AM
Ammi's Avatar
350 Detroit Muscle
Same. Mine came out real easy.
Old Oct 24, 2004 | 08:28 AM
Tek-Niq's Avatar
my rear view mirrors flap like a f-ing bird
mines didn't. try to use a screw driver that has the same size head on it as the screw so you won't strip it. with some elbow grease it should come out. if you got something like a ratchet wrench with a screw diver bit would be the best bet.
Old Oct 24, 2004 | 11:45 AM
Tony Fernandes's Avatar
Another way I've tried is to use a screwdriver and a vice-grip wrench. Attach the wrench to the screwdriver to make it easy to turn and put all your weight on the end of the screwdriver so it doesn't slip, and then turn like a ratchet.
Tony
Old Oct 24, 2004 | 11:48 AM
PoLo's Avatar
2-Wheelin it...
rosey treating you well
Stelianos
Aug 24, 2015 12:13 PM
maxipower
Aug 21, 2015 11:10 AM
Stelianos
Aug 19, 2015 02:07 PM
kirkhilles
Aug 8, 2015 10:53 AM
