Is this a rip off or not
Old Oct 24, 2004 | 04:07 PM
nysemt1's Avatar
Hey people, I'm coming up on 30k miles on my 2k3 and my local dealership wants to charge me $499.00+Tax - $599.99+Tax with Plugs for the following
-Complete Lubrication,
-Repalce Motor Oil,
-Replace Oil Filter,
-Adjust all Fluid level,
-Replace A/T tranny fluid,
-Replace antifreeze and bleed system for air,
-set tire pressure,
-visually inspect tire condition,
-rotate and blalance 2 front tires,
-inspect timing and emission control,
-inspect HC/CO,
-replace air and fuel filter (if applicable),
-inspect emissions carbon cannister,
-inspect suspension,
-inspect exhaust system for leaks, cracks, chafing, abrasion, deterioration etc.,
-inspect axles and u-joints,
-adjust brake and parking brakes,
-inspect pads and linings,
-lubricate all hinges,
-inspect all hoses & belts - adjust if necessary,
-complete safety inspection,
-service throttle body,
-service battery & inspect charging system.
I'm just thinking to myself, that's a lot of moeny just to inspect most of these items. I drive my car mostly in the suburbs so it's a mix of highway and city driving, all comments are appreciated!!!
Old Oct 24, 2004 | 04:21 PM
Lontar1's Avatar
Puerto Rico-Maxima Lover
You can do most of those things.. and remember "Inspect" that means they are going to find something to screw you... so don't..... I mean is your money...but don't waste it...
Old Oct 24, 2004 | 04:41 PM
scopium
go buy the stuff and have mechanic do the labor for u
Old Oct 24, 2004 | 04:42 PM
maximadave's Avatar
detailerdaveb@gmail.com
not worth it IMO. Just do oil change, tranny fluid change, air/oil filters changed, in-cabin microfilter changed and you should be fine. Your plugs are suppose to be 100K plugs and your radiator fluid does not need changing this soon.
Old Oct 24, 2004 | 05:05 PM
Maxceler8's Avatar
meh
Mine's coming up on this soon too....was a lil worried that 1.) it would be that much, and 2.) that it's very important and I absolutley couldn't do it myself, or take it elsewhere.....
good to know
NismoMax80's Avatar
SuPeRmOd
WOW, they really want to charge that?
Most you can do on your own: oil, oil/air/micro filters, Adjust all Fluid level, set tire pressure, visually inspect tire condition, rotate ALL tires.
I may ask them to: Replace A/T tranny fluid, Replace antifreeze and bleed system for air, balance tires. If you thought important.
The rest is unnecessary unless you're having problems. Most of them get checked with state inspections.
Old Oct 24, 2004 | 05:32 PM
SoonerFan's Avatar
Cletus
if i lived closer i would do it for you for $300.
NEVER pay for routine maintenance at the dealership.
Old Oct 24, 2004 | 07:40 PM
5 spd's Avatar
you can "inspect" those items listed above if you have a haynes or chilton's manual(found at local bookstores or auto parts stores), and maybe some basic tools.
-complete lubrication (lubrication of what?)
-replace motor oil (which is part of lubrication, if not ALL of lube)
-replace oil filter (normally part of an oil change, no need to differentiate this from the oil change. just another line to make the service look all that much more complicated)
-adjust all fluid levels (what is there to adjust? IF any of your fluids are low, they are just going to top it off. for the price listed above, I think a flush for ALL of the fluids in your car should be replaced with new fluids, i.e. p/s, brake fluid, coolant, etc..)
-tires (set pressure-ok, you cant do that yourself? rotate two front tires and balance - why cant they do all four? also a visual?)
-complete safety inspection (this is just a certified mechanic going off a checklist to make sure the safety features are in ooperating order on your car, headlights, seat belts, etc.)
basically, anything that says inspect, you could do yourself unless it requires looking underneath the car to visually see the drivetrain, suspension. chances are, if you haven't jumped your car, it should be fine.
I know there are other items that I have overlooked or not commented about, but please, PLEASE, don't pay $499-599 for the 30k service. if you are unsure, or just dont want to deal with the service on your own for various reasons, then check out a local mechanic to see if they offer the same services. more than likely they do, and at a fraction of the price.
cliff notes: you are gonna get raped if you get the $499 30k service
Old Oct 24, 2004 | 08:43 PM
irish44j's Avatar
retired moderator
All that stuff can be done for $50-$100 in materials and about 3-4 hours in your driveway......none of it is difficult. As stated above, get a Chilton's or Haynes manual from the local auto parts store and it'll tell you how to do all of it.
I can't believe anyone would pay $200 much less $500 for the "dealer service" packages. Some people just have too much money
Old Oct 24, 2004 | 10:06 PM
maximo-SE's Avatar
1.Oil Change
2.AT Transmission Change
3.Air Filter Change
4.In cable filter change
5.New wipers
6.Tires rotated
7.Tire Pressure checked
(what do they mean by lubing the chassis? isnt the chassis lubed already?)
So all i need to do is when i reach 30000 miles??
Old Oct 24, 2004 | 10:45 PM
scopium
as long as you do your oil changes on time... you shouldnt really worry about antying else..
Old Oct 25, 2004 | 02:37 AM
TZapper's Avatar
I have just received a promotion in my mail from Nissan allowing me to have a free 100-point inspection of my car.
Old Oct 25, 2004 | 06:19 AM
SKYRockerr's Avatar
I am around 27K, Only think you should be paying for is oil, a oil filter, air filter, incabin filter, you can do your tranny flush if you want too.. here's a easy to do you own service.
if it makes noise then then lube it, if it doesnt then its fine.
if doesnt feel right then worry about it.
if it doesnt smell right, then worry about it.
if it doesnt run right, then worry about it.
if it works, drives, stops moves, and feels good. then keep your $$ in your wallet.
cars know when you get money, thats when they start asking for new parts!!!
Old Oct 25, 2004 | 07:00 AM
desperado_45's Avatar
Ya at most all you really need at 30k is an oil change and transmissions fluid change (not worth the hassle to DYI).
good to know
Old Oct 25, 2004 | 07:49 AM
boondoxmax's Avatar
big rip of. i had my 30,000 service done for 175.00 not including spark plugs which i won't have changed till around 60,000
Old Oct 25, 2004 | 08:00 AM
Robdog69's Avatar
Nissan Tech Here
OK, here it goes. These prices are a joke, I work at buckeye nissan in OHIO and I know what we do to get money from customers and what not. Our hourly rate is $80 including any diag before work begins. This service they quoted you on is based on a 30 or 60k service, which does include all that listed but 50% of the stuff does not get looked at except a real quick glimpse just to see if its ok. It is not worth the money. It takes a tech a max of 2.5 hrs to do the full service and the tech only makes about $15-$18 an hour. So nissan is taking this money all for themselves. You can easily do all this at home like the other guys are saying in the previous posts. Dont screw yourself out of $500 for a free car wash and fluid replacements... Unless you are just lazy and dont have nothing better to do with your money.
Just a heads up.......
Old Oct 25, 2004 | 09:11 AM
Yaco_Max's Avatar
mm.... Do it your self, last monday I took my lazy extra day-off, after reading some post about this issue ....I did it almost everything BC I'm still thinking about the seafoam.... and I kind of new in all this but hey......WTF you can use that money to buy something else in your car.........
Old Oct 25, 2004 | 11:17 AM
mike_747's Avatar
Here's the deal. I owned an 89 Maxima for 11 years and never once took it to the dealer for maintainance. I change my own oil/filter, check fluid levels, replace plugs as needed- the end. Things I pay for include brake jobs, transmission service and cooling system service. Tranny and cooling should be done every two years. Other than repairs, the above should cover a newer car. I probably saved $1,500+ over 10 years by NOT going to the dealer for basic maintainance and inspections.
Old Oct 25, 2004 | 11:36 AM
Love_00_Max's Avatar
I stopped taking my Max to a dealership after 36K and I do all the regular maintainence by my self -- oil/filter, tranny fluid, filters, coils and plugs, brakes, coolant and the recent change was to regrease the starter motor.
All that one needs to do is sit in this forum and learn!!! and offcourse share your experiences both good/bad.
Old Oct 25, 2004 | 11:45 AM
2K3MAX2NV's Avatar
"tse-tse fly"
Whats An In Cabin Filter Change And How Do I Do It?
Old Oct 25, 2004 | 12:13 PM
NismoMax80's Avatar
SuPeRmOd
I called them about that, and they said don't bother. That confirms what my certified mechanic friend says "They know you have a well built car, and if there were problems, you would already know and report them. They will just say they checked everything or give a quick glance." Basically if you do the simple maintenance, you only need these inspections to confirm possible problems.
But if you have $$ to waste, sure, it will look good on your car's history for sale later, or warranty concerns.
Old Oct 25, 2004 | 12:14 PM
NismoMax80's Avatar
SuPeRmOd
filter for air conditioning. it's in the glove box. manual should say how to access it.
Old Oct 25, 2004 | 06:47 PM
vmax8's Avatar
Thanks for insider info!
Old Oct 25, 2004 | 06:51 PM
dmplus's Avatar
EXACTLY!!!!!!!
Change the oil call it good, spend 500 bucks on something useful rather than your stealerships (or other mechanics) pocket.
Old Oct 25, 2004 | 07:11 PM
BlackBIRDVQ's Avatar
drag racing is for wussies
Err Mr Nissan Tech, Nissan does not make any $$$ from services that the dealership sells to customers. Tech who makes that 15-18 bux a hour (is really a fool for working for low scale like that) books depending on the dealership- 3-4 hours to do the 30K-60K maintenance. So that only puts the dealership at around 70 bux or so to pay him to do this. Then you gotta figure in oil filter is like 4 bux, oil is around 5 bux, brake fluid is bout 2 bux, tranny fluid is around 20 bux, wipers are 20 bux, in-cabins are 45 bux, air filter is around 15 bux. White lithium grease in the can is probably like 5 bux. Add this all up, and you will have around 150 bux in parts. Now you have around 220 bux in Labor and parts, and the 300 bux goes towards the dealerships profits. I worked for Nissan, I'm a Nissan Master Tech as a matter a fact. **** for 550 bux I will do a clutch and 30K for ya. Seriously its a big rip off. When I worked at Lexus we didn't even charge that much for a 30K service on a LS430, and you got a nice cushy Lexus loaner car for the time your car was in for service !
Old Oct 26, 2004 | 12:15 AM
Wisky97SE's Avatar
Nissan dealers are the devil, avoid them at all costs.
Old Oct 26, 2004 | 02:08 AM
nyautostyle's Avatar
^^^^ agreed
Old Oct 26, 2004 | 08:04 AM
maximo-SE's Avatar
Check out Housecor's website, hes on every orger's bookmarks.
Old Oct 26, 2004 | 08:34 AM
SkoorbMax's Avatar
Yes, it's a huge ripoff. Only suckers pay for these expensive 30k,60k,etc. stealership rear violations.
Old Oct 26, 2004 | 08:54 AM
Y2KMaxGXE-R's Avatar
look, don't be stupid, just open your owner's manual and see what exactly needs to be done at 30K mi. At 30K you don't need to replace your coolant, and replace anything other than engine oil, oil filter, and just check the level of all fluids. The list above is a scam.
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
mikeg75
Nov 30, 2015 05:12 PM
Derrick2k2SE
Nov 19, 2015 10:14 PM
worldwiderecognized
Sep 24, 2015 06:56 PM
95naSTA
Sep 21, 2015 06:50 PM
