How low can I lower with a 245/45/18 rim and tire combo
i have a 18x7.5 with 235/40 series tires with 42mm offset and 15mm spacer in the rear and it doesn't rub at all after I trimmed off the little tab underneath the rear fenderwall. I am running about 1/4-1/2 inch drop all around
i want to go lower than 1/2 inch. I am looking at about 2 in the front and 1.8 in the rear. Will i be able to do this, and yes i actually have a 245-45-18 with a 7.5 inch wide rim and 42 mm offset.
Is it possible to go with a different size tire in the front than in the back . Like say i kept 245-45-18 in the back and went with a 245-40 in the front. Would this look stupid or mess anything up?
more sidewall could have a higher possibility on rubbing. Plus you wouldn't be able to rotate your tires cause you have different sizes between the front and the back. I don't know why you'd run the 245/45-18 in the first place
Are these 2k4 SE rims we are talkin about here? Becuz the specs you gave me (245/45/18 42mm offset 7.5 wide) is exactly wut a 2k4 SE comes with.....
If so, why did you buy these rims? I mean they are nice looking but in the long run, these rims are real heavy, the tire size isn't correct, and I'm sure you can't go real low with these unless you get spacers or such....42mm on 7.5 wide is pretty tucked in for a 5th gen....So I'm sure you will rub if you go pretty low
Should have just bought the correct tire size for these rims....you can run either 245/40/18....or if he is worried about denting his rims, he can run 225/45/18.....both tires are within spec...
I have the 2k4 se rims, and they dont seem heavy to me. :dunno: my car is a weekend car, and there is no bling bling on this. minimal mods at most, for now. as far as upgrades are concerned, I am not trying to squeeze every bit of hp or weight savings, so if a stock wheel is heavier than an aftermarket wheel, so be it. I opt for the factory look.
EDIT: I am on JIC's A2's, with a finger gap all around. I rub in the back on hard dips going fast and speed bumps. front rubs only when turned all the way to one side going over a bump. I will wait until my tires wear out before I upgrade the tires, or whole setup. definitely staying with 18's.
MR2 T'd
Jul 9, 2021 05:06 AM
