How do you lube your doors?
Old Oct 27, 2004 | 04:51 PM
pvaudo's Avatar
I've had some difficulty with this in all 3 of my Maximas..
Near the hinges is a little flat rod thing that slides in and out of the door that needs lubrication. In my 93 it was metal and not too difficult to get some grease in between the plates, but on the 5th gens it is a solid black plastic thing.
Do I just glop some grease all over the outside or is there a better way??
P.S. I have used plain white lithium grease in the past. Is that good enough?
Thanks.
Old Oct 27, 2004 | 06:05 PM
maxima0002's Avatar
I've used White Lithium Grease, but that didn't seem to do the trick. Anyone.?
Old Oct 27, 2004 | 06:47 PM
Qmax03
..wd40 ! i always use that jsut spray over the 2 big hinges and that black one that goes into the door and call it a day.
Old Oct 27, 2004 | 07:26 PM
spirilis's Avatar
maybe Silicone Spray?
Old Oct 27, 2004 | 07:27 PM
Igor911's Avatar
I use lithium Grese (sp?)
Old Oct 27, 2004 | 07:50 PM
aliti19's Avatar
Maxima addiction cured w/ the GS pill
WD40 seems to do it for me.
Old Oct 27, 2004 | 07:51 PM
Anuj's Avatar
yeah when it was squeaking like crazy, nissan used lithium grease
when it started happening again in 2 weeks, i sprayed wd40 and it hasn't squeaked in 1 month since
Old Oct 27, 2004 | 08:06 PM
roofadoofalus's Avatar
lubrication is always a good thing
Old Oct 27, 2004 | 08:12 PM
Anuj's Avatar
have some on your hand, roofadoof? lol
Old Oct 27, 2004 | 08:28 PM
scopium
elbow grease works too
Old Oct 27, 2004 | 08:46 PM
elbow grease is ok, but lubrication is definately needed
Old Oct 28, 2004 | 06:36 AM
aliti19's Avatar
Maybe some KY would be a good door lube. There are other uses for it you know.
Old Oct 28, 2004 | 05:49 PM
pvaudo's Avatar
I tried WD40 and Silicone spray in the past, but it wears out too quickly, especially when there's a lotta rain.
I'm still trying to figure out the black plastic thing though.. does friction occur on the OUTside of this thing (I cant see any wear marks) or is there a hidden slider inside that I can't get at.. dunno. Like I said before, the 93's had metal plates instead, and you could get the goop in between the plates. The 5th gen is just a solid plastic block.
Old Oct 28, 2004 | 06:39 PM
kidkay's Avatar
WD40 for life, endless lubrication.
Old Oct 29, 2004 | 08:25 PM
young1976's Avatar
the black plasic thing has detents in it to allow the door to stay open at two places.. if you notice the two distinct detents when you open the door slowly. But if you lube it then you'll bearly feel it. I spayed silicone on my hinges and that plastic covered metal ( think it's metal underneath) and I can't feel anything. The door just swings open and close too easy.
Old Oct 29, 2004 | 08:34 PM
i dont suggest using KY for this purpose
Old Oct 29, 2004 | 09:04 PM
Ammi's Avatar
350 Detroit Muscle
I just use WD-40
Old Oct 30, 2004 | 07:45 AM
how does that work for you
Old Oct 30, 2004 | 11:23 AM
Ammi's Avatar
350 Detroit Muscle
works just fine
Old Oct 30, 2004 | 11:31 AM
i hope this helps pvaudo
Old Oct 31, 2004 | 02:56 AM
pvaudo's Avatar
I'm just gonna go with the WD40... again, and again and again...
Thanx guys
REDinLV
Aug 15, 2024 12:30 AM
trsandrew
Apr 8, 2016 06:45 PM
magiconthetire
Oct 26, 2015 09:03 PM
trsandrew
Oct 25, 2015 02:47 PM
BobTX10
Oct 7, 2015 08:43 AM
