Clutch problems ?? advice ??
Old Oct 28, 2004 | 07:41 AM
maseo77's Avatar
Yesterday morning for some odd reason my clutch pedal feels unusually soft but the car drove fine. Later that night I go to start the car and the clutch pedal stays on the floor. I checked my master cylinder and the reservoir is empty! I added the needed amount of brake fluid but that didnt help, the fluid just sat there and didnt move so now im guessing I have to replace the slave cylinder hose because I see a slight leak on top of the transmission. Nissan tells me they have to replace the master cylinder and the slave cylinder. any ideas on what I should do?
Old Oct 28, 2004 | 08:16 AM
Raven's Avatar
this is bizarre, I just had this exact problem last week and I have 85K on my beast. I have a friend who is a mechanic and he said my master cylinder was in decent shape, but the slave cylinder and flex hose that attached to it both were failing. I don't know what to tell you other than the dealer will try to get you replace the entire unit (master + slave). The parts are only around $50-$80 a piece, but I wouldn't even know how to attempt at the labor.
Good luck and be careful about that flexhose! They found out that mine failed after they had installed the slave and had to redo the entire thing. I think this is common and now I'm waiting for the clutch to give out within the next 10-15K miles.
Remember, if you get stuck, keep adding fluid so you can atleast get it to the mechanic and avoid a tow!
Old Oct 28, 2004 | 08:46 AM
maseo77's Avatar
I am planning on replacing the slave cylinder and the hose. My master cylinder looks fine but when i add fluid to it and pump the clutch 100 times the fluid level doesnt drop meaning I have no pressure in the lines at all.
Old Feb 15, 2007 | 06:59 PM
88MaximaSE's Avatar
how do you add fluid to the tranny
Old Feb 16, 2007 | 06:31 AM
carsarecool's Avatar
Where is the clutch slave cylinder? I know the master is right down next to the brake booster...or am I mixed up?
Old Feb 16, 2007 | 03:11 PM
tool46&2's Avatar
I had all my clutch fluid leak out years ago on my 94 max when it got real cold out. I just added more fluid to the system but it requires that you bleed the clutch cylinder just like you would a brake piston. There should be a bleeder valve where the slave cylinder goes into the tranny. After I bleed my system and got fluid back into it I couldn't find a leak and the resevoir has never gotten low again (over 5 years later).
I can't explain why the fluid was all gone but my only guess is that it had gotten so cold ( I was living in North Dakota at the time) that a seal allowed the fluid to leak but eventually re-seated itslef or something like that. I had talked to someone else who had the exact same unexplainable situation as me.
Anyways my whole story was to warn that you can't just add fluid to the resevoir, the system has to be bleed. Then see if it leaks out again.
Old Mar 10, 2007 | 05:56 PM
tonyc7903's Avatar
I had a similar problem and I switched both the master and slave cilynder but now I hear a noise when I press the clutch pedal, very loud. does this mean I need a new clutch?
Old Mar 10, 2007 | 06:00 PM
datdude20's Avatar
its da house thingy.....i had the exact same problem
Old Mar 10, 2007 | 06:10 PM
tonyc7903's Avatar
I don't know which house thingy
Did I not bleed it right?
PS I found all the directions for bleeding here
http://www.motorvate.ca/mvp.php/803
It's for an older model but the clutch seemed to be the same
Old Apr 6, 2009 | 11:03 PM
Gurmu1's Avatar
Can anyone recommend a clutch replacement for a 2002 maxima. How are the Exedy clutches?
Old Apr 7, 2009 | 10:08 AM
Ahmad_1290's Avatar
I heard the VQ35HR Clutch is a pretty good replacement.
Old Apr 7, 2009 | 10:30 AM
Gurmu1's Avatar
Is that a Nissan item?
Old Apr 7, 2009 | 12:34 PM
Ahmad_1290's Avatar
yea its is search it
Old Apr 7, 2009 | 12:48 PM
Progress's Avatar
It's business time.
Close this thread, it's old. There is a sticky for questions like this.
Mar 12, 2020 12:06 AM
BkGreen97
Apr 2, 2016 05:47 AM
14GmMax
Sep 17, 2015 09:08 PM
NissanNismoZ
Sep 12, 2015 07:30 AM
2012Maximus
Sep 10, 2015 12:50 AM
