Sunroof problems on a 2K
Old Oct 31, 2004 | 04:56 PM
Ivanhoe's Avatar
Hi guys, I am new to the form and I have just picked up a 2K Maxima. The only problem I have is that the sunroof opens intermittently (I have to keep pressing the button) and also both buttons do the same thing. Any ideas? Thanks!
Ivanhoe
Old Oct 31, 2004 | 05:47 PM
ihavea5spd's Avatar
ok, here's what you do. close your sunroof. unhook your battery. stomp on your brakes a few times. turn your lights on and off. (you're draining the power
in the system). hook your battery back up. turn on your ignition. tilt the sunroof
up, and then back down. now it'll work.
Old Oct 31, 2004 | 06:08 PM
Ivanhoe's Avatar
Thanks for your help. Will do that. Any reason why it happens?
Old Oct 31, 2004 | 07:28 PM
ihavea5spd's Avatar
dunno, but it's happened to quite a few people. your dealer will try to sell
you a $300 motor. this procedure is kinda like rebooting your pc.
Old Nov 1, 2004 | 08:04 AM
Ivanhoe's Avatar
This did not work for me but maybe I am doing something wrong. Do I need to disconnect both poles on the battery? (I only disconnected the negative)
Old Nov 1, 2004 | 08:34 AM
ihavea5spd's Avatar
yes, both poles. try it again.
Old Nov 1, 2004 | 08:19 PM
ihavea5spd's Avatar
well???????????
Old Nov 8, 2004 | 07:17 AM
Ivanhoe's Avatar
Still nothing. What now?
Old Nov 8, 2004 | 10:36 AM
maseo77's Avatar
leave it disconnected for atleast 30 mins
Old Nov 8, 2004 | 10:52 AM
ihavea5spd's Avatar
hmm. strange. this always works. are you "draining" the battery by depressing the
breaks and turning the lights on? and did you hit the TILT button and not the back/forth button when you hooked the battery back up?
Old Nov 8, 2004 | 11:15 AM
Ivanhoe's Avatar
discoed for 30 min. Pressed the tilt button (open).
Old Nov 8, 2004 | 11:34 AM
Ghase's Avatar
I wish I could help with problem, but I have one of my own. The sunroof's leaking from the passenger side !!!!!! Any help guys???
Old May 25, 2006 | 10:04 AM
jpilapil's Avatar
Help
I am new here and I have a nissan maxima 2001 w/ 98k mile already. I plan to do the engine oil change by myself. I read the manuals but it doesn't say how many quarts of oil should I use but instead I have to depend on the dipstick. My obvious question is, how many quarts of oil I have to use? What brand of oil filter I have to use? I know I can determine the amount of oil by using the dipstick but I just want the estimate number of quarts of oil. Thank you in advance! JP
Old May 25, 2006 | 10:21 AM
RocketMAX's Avatar
I found this in the 2000 NISSAN Maxima Service Manual.
Recommended Fluids and Lubricants
ENGINE - US Measure - Changing Instructions
With oil filter change - 4-1/4qt
Without oil filter change - 3-7/8qt
Dry engine (engine overhaul)- 5-1/8qt
NISSAN's reccomendation
SAE 5W-30 viscosity oil is preferred for all temperatures. SAE 10W-30 and 10W-40 viscosity oil may be used if the ambient temperature is above -18°C(0°F).
Old May 30, 2006 | 03:03 PM
1MaXXfan's Avatar
Here ya go
Ivanhoe
http://www.nissanhelp.com/Ownership/.../NTB01-021.htm
Mar 12, 2020 12:06 AM
Blkkn8
Sep 15, 2015 06:57 PM
Vequity
Sep 10, 2015 05:26 AM
mikebla
Sep 3, 2015 05:37 PM
