Car dying when idling at a stop
Old Nov 2, 2004 | 08:08 AM
Stephen Max's Avatar
Howdy all,
I don't usually frequent the 5th gen forums, but my wife's 2k Maxima has been running just a little rough lately with a bit of hesitation when accelerating, and it occasionally just stops running when idling at a stop light. It starts right back up.
Does this sound like a maf sensor problem? Any other things to check?
Thanks!
Old Nov 2, 2004 | 08:28 AM
CCS2k1Max's Avatar
Time to clean up the TB.
Old Nov 2, 2004 | 09:17 AM
fatboyp's Avatar
Sounds like it could be the MAF sensor. I had similar symptons on my 2k SE(hesitation, cold start stuttering) and a new MAF was the solution. You can order one from JR Nissan or DaveB for a slightly less than $100 and install it yourself. I had mine installed by Nissan so that I could get the ECU reprogrammed.
Old Nov 2, 2004 | 09:28 AM
twllin's Avatar
Thats What Happened To My Maf Last Week I Got One From Dave B For Like 90 Shipped!
Old Nov 2, 2004 | 09:45 AM
2K3MAX2NV's Avatar
"tse-tse fly"
Had The Same Prob Cleaned The Air Filter No More Problem Id Change The Maf As Well
Old Nov 2, 2004 | 09:48 AM
lex3015's Avatar
TB or MAF most likely
Old Nov 2, 2004 | 12:20 PM
Matt_01SE_20th's Avatar
MAF definately. i had this problem and spen forever thinking it was the fuel because when i checked the pressure it was low, so i figured FPR but it turned out to be the MAF. got it replaced and the thing pulls really hard and steady. no stalling since then.
Old Nov 2, 2004 | 12:52 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
MAF....call the real DAVEB.
Old Nov 2, 2004 | 12:56 PM
I just got off the phone. He has one with my name on it ready for me to pick up this afternoon.
Thanks Dave, if you see this.
Old Nov 2, 2004 | 05:46 PM
twllin's Avatar
very easy to install too
Old Nov 2, 2004 | 07:05 PM
ZIPPIN's Avatar
Mauja He Mauja
sea foam
Old Nov 2, 2004 | 08:19 PM
dgmaxse's Avatar
I have the same problem. I put on a k&n cone filter with MAF adapter and changed the spark plugs. Spark plugs needed changing after 90k of use and my stock intake inlet was falling apart. I still have the problem. I think I'll try cleaning the throttle body as suggested. I think blackbirdvq said he could get the sensors for the MAF for cheap, so you may want to ping him for that. Again I think that’s what he said, maybe not, but it may be worth asking. I might be doing the same thing soon but I wanted to try things that I know need work first before spending money unnecessarily. I’ve tried testing the MAF with a multi-meter, but I don’t think I’m doing it right.
Old Nov 3, 2004 | 07:58 AM
exunaja's Avatar
I recently posted similar issues (idle problem, engine shuttering at idle, engine shuttering at start up) with my Y2K and no good response. Anyway, how do we check MAF is failing? How do I know that my coil is bad too?
Is Autozone can pull the code without SES on and identify this issues?
Old Nov 3, 2004 | 09:08 AM
when my car lost power i checked the MAF as a posibility and everything checked out on the multi-meter & no MIL (SES). i looked to the fuel system and brought it in for a new pump/pressure regulator. it turned out to be the MAF. i guess there is alot of things that can go wrong with the MAF and still have it opperate within normal ranges, but the engine will let you know in its own way.
Old Nov 3, 2004 | 11:18 AM
tkarrh's Avatar
pull any codes from the ecu. I has similar problems and had my ecu updated. Also I had my tps changed and no more cutting off.
Old Nov 3, 2004 | 12:06 PM
takkar's Avatar
can someone post pics, and circle where the MAF is located?Thanks guys...
Old Nov 3, 2004 | 12:12 PM
icepick's Avatar
its the maf but honestly if you would of goten a 3rd gen you wouldnt have this problem !!!
Old Nov 3, 2004 | 12:17 PM
I installed the new maf and my wife said that so far the car is behaving normally.
The maf came with instructions saying to have the ecu reflashed, but I didn't and it seems to run fine with no hint of leanness or richness.
Why does the ecu need reflashing? Is the new sensor calibrated differently?
Old Nov 3, 2004 | 12:24 PM
Find the air filter housing. Coming out of the back of the filter housing (on the way to the throttle body) is a plastic tube with an electrical connector at the top. The tube is the maf sensor housing, and the sensor itself is the electrical part that is inserted into it from the top. When you buy a new maf sensor, it comes with the housing. (At least mine did.)
Old Nov 3, 2004 | 03:36 PM
twllin's Avatar
its a totally diff MAF according to dave b. there was the stock one which runs about 465 or so but the one you and i prob got for like 90 or so has some type of update. I didnt reset my ecu either but i plan to when i have the time
Old Nov 3, 2004 | 03:37 PM
twllin's Avatar
also if any of you guys think its the coils theres a really good deal for them in the GD section 215 shipped for 10+ people and theres already 6
Old Nov 3, 2004 | 04:18 PM
BLKMAX005SPD's Avatar
MAF...mine did the same thing...
all you need is that
Old Dec 9, 2004 | 06:42 PM
dgmaxse's Avatar
Mine did that too, the exact same thing. Just replaced my MAF today, so we'll see if that solved my problem. Don't forget to reset the ECU when you do the MAF see this thread --> http://forums.maxima.org/showthread.php?t=360385
Lakersallday24
Jun 16, 2019 01:35 AM
maxinout93
Oct 27, 2015 01:29 PM
doobadoo
Aug 15, 2015 06:43 PM
Maxboy23
Aug 11, 2015 11:59 AM
kirkhilles
Aug 8, 2015 10:53 AM
