Whurring noise on highway...
Old Nov 2, 2004 | 02:44 PM
TheBigDu's Avatar
I recently had my 2k2 on the first long highway trip since the I got it (a few weeks ago) and I noticed something odd.
If I keep the engine at about 2400-2500 rpm I notice this whurring noise coming from it. The noise is not very loud, but I did hear it slightly over my music. Everytime the tach passed by that point, I noticed the noise. There's no loss of power or shaking or anything accompanying it, just the noise.
Anyone else experience this and can offer some insight?
Thanks,
Brian
Old Nov 2, 2004 | 04:12 PM
Edward Lee's Avatar
Could it be the fan clutch?
Old Nov 2, 2004 | 04:37 PM
NYC TAR's Avatar
check out the wheel bearing. It's commom on the maxima for wheel bearing to go out, but they usually get replaced under the warranty.
Old Nov 2, 2004 | 07:21 PM
TheBigDu's Avatar
I don't know why it would be the wheel bearing if I only hear it at about 2500 rpm, it doesn't have anything to do with the speed I'm going.
I should also note that this is an Automatic, I don't know if it makes a difference or not, but it might.
Old Nov 2, 2004 | 07:27 PM
BlackBIRDVQ's Avatar
drag racing is for wussies
WHat speed is this noise coming at ? RPMs don't mean much really. Unless it does it in every gear at certain RPM, then it could be a bad catalitic converter going bad, or it could be torque converter pump. If it does it at certain speed only in one gear- then it could be wheel bearings- we need more info.
Old Nov 2, 2004 | 07:46 PM
TheBigDu's Avatar
I'll do some highway driving tomorrow and see if it's just one gear or not, guess i'll have to shut OD off to find out. I'll let ya know.
Old Nov 2, 2004 | 08:17 PM
5 spd's Avatar
sounds like the elec fans for the radiator.
Old Nov 2, 2004 | 08:21 PM
Fans do not work with the car moving, over 35MPH the ECU will not signal the fan control module or fan relay to turn the fans on. It will have enough air flowing over the radiator at 35MPH+ to cool on its own without fan assist. And no Maximas do not have viscous coupling fans on them like RWD cars do- most newer RWD CARS- not trucks, do not use those anymore.
Old Nov 2, 2004 | 09:06 PM
raiste's Avatar
You don't happen to have an iPod or other MP3 player connected through your tape deck (and powered from cig lighter) do you?
If so, could be a ground loop.
Old Nov 2, 2004 | 09:26 PM
TheBigDu's Avatar
No, just using the factory in-dash CD player (for now).
Old Nov 2, 2004 | 10:03 PM
Fezzik's Avatar
Yeah i get the same thing at 2500 rpms when accelerating (louder) or decel (quiter) in all gears on my 6 speed. Is it kinda of a metalic whirring sound?
Old Nov 2, 2004 | 10:10 PM
Fezzik- your car, it might be a few things. Flywheel might be damaged- its dual mass and they love to make all kinds of weird noises. Since you have headers, then it shouldn't be your rear bank pre-cat. I am thinking something inside the tranny- differential bearings ? Does it do it with the car in neutral ? clutch in or out ?
Old Nov 2, 2004 | 11:04 PM
Fezzik's Avatar
It does it only in gear and at 2500rpm driving. i havent heard it in neutral
Old Nov 2, 2004 | 11:06 PM
TheBigDu's Avatar
Yeah, and I'm pretty sure mine does it in all gears too. (auto)
I guess Fezzik's could be someting different, but that'd be very coincidental, seeing as how it's at the exact same rpms and I also agree with the louder while accel. and quiter while decel. thing.
Old Nov 3, 2004 | 07:01 AM
ColdSHO's Avatar
i notice the same noise in all my gears too, my engien seems to vibrate a little bit too. im pretty sure my wheel bearings are shot and so are my rotors, so that could be where the vibrations are coming from. too many problems all at once.
Old Nov 3, 2004 | 08:02 PM
maximus nismus's Avatar
how are you tires...could just be the road. someone paranoiddddd
my 01 does that too but its just i need new tires....look at your tread, they sometimes make noise then pattern are off
Old Nov 3, 2004 | 09:09 PM
vortechpower's Avatar
maybe it is your belt. too loose or too tight. check your air filter. does this happen when you are stopped at the rpm's?
Old Nov 4, 2004 | 07:41 AM
TheBigDu's Avatar
brand new ContiExtremes, only happens at 2500rpm, has nothing to do with speed
Old Nov 4, 2004 | 08:31 AM
Fezzik's Avatar
Well with my mechanical knowledge. I am sure its not the air filter, not the belt. It only happens when moving at 2500 rpm
user 11122324
42
Jul 18, 2022 03:35 PM
aw11power
Oct 10, 2021 04:57 AM
D Mason
Jun 21, 2016 04:43 AM
uttadms31
Sep 30, 2015 05:24 AM
