progress allumina question?
Old Nov 3, 2004 | 09:05 AM
BIGMAX19's Avatar
My new suspension was put in and now i here little noises when i hit any kind of hole in the street. Not a pot hole but any uneven surface. is this normal? The rear left spring doesn't fit properly on the allumina shock, the last ring is a little bit bigger than the surface that it is suppose to sit upon on the shock and my left front makes little noises and i also here little noises coming from the driver door. Does anybody have the same problem.
And is there a special way to get a wheel alignment when your car is lowered. meaning, can i got to any wheel alignment garage or to some kind of specialist cause it seems that even when aligned it still isn't perfect.
Old Nov 3, 2004 | 09:15 AM
jeepik's Avatar
were the springs put together right???
doesnt sound like it
Old Nov 3, 2004 | 09:20 AM
BIGMAX19's Avatar
how would i know... ??? Should i not be hearing any noises at all...even the door thing as though my car was stock????
Old Nov 3, 2004 | 10:12 AM
njmaxseltd's Avatar
I bet you have a left rear shock for a 4th gen. Thats the differance between 4th gen rear shocks and 5th gen shocks. The lower perch is a different size.
Old Nov 12, 2004 | 04:49 PM
G-STYLE02MAX's Avatar
Sounds Like A Bad Job You Ask Me Progress Springs Give To Much Drop I Have Illuminas With Eibach Springs Allso Get Little Sqeek Noise On Bumps Just Turn The Radio Up
Old Nov 12, 2004 | 05:35 PM
ZeRo MaX's Avatar
I know a lot of people with Illuminas and Tein S-tech springs and no weird sound from them...
Old Nov 12, 2004 | 08:37 PM
Puppetmaster's Avatar
This is the 2nd time you've posted that Progress springs "Give To Much Drop"... I'd like to hear your reasoning for that statement, because no one else, to my knowledge, has made the same claim.
Just curious, that's all... I know you're entitled to your opinion... I'd just like to learn more about it...
Old Nov 12, 2004 | 10:36 PM
sooner02r1's Avatar
How does your progress/illumina setup ride? Does it beat you to death or is it tolerable. Im considering that combination. I love how it looks.
Old Nov 13, 2004 | 06:50 AM
housecor's Avatar
Go get an alignment. But before you do, double check your install to make sure the springs are sitting properly in the perch and everything is installed correctly.
Old Nov 13, 2004 | 07:08 AM
IgS's Avatar
IgS
i have progress/illuminas....first i dont think the drop is too low, i think its perfect and i dont hear any noises on the road, i might occasionaly hear something when i turn the wheel completely to the left or right and go off the driveway....
Old Nov 13, 2004 | 11:05 AM
Ghase's Avatar
Check all the bushing in the front. I think it mite be your control arm, Stabilizer bar, or your bump stops(may need to cut them) in the front.
And yes I have the same problem with my H&R spring, I just don't have the time to mix it.
That should help!
Old Nov 13, 2004 | 11:42 AM
I have Tokico HPs/Progress springs... the drop is sweet... the ride is comfortable... except for mid to larger bumps and speed bumps.... highway driving has been good to far....
EDIT: I did not cut the bumpstops...
Old Nov 13, 2004 | 12:13 PM
00MaxSE's Avatar
Pointy Elbows
Yeah, did you trim your bump stops? That might be it.
I have Progress/Illuminas and no problems so far. The ride is great IMO. A little harsher over the bumps with my 19"s but otherwise fine.
Old Nov 13, 2004 | 06:29 PM
To Much Drop For 19's I Like To Ride With Illuminas Set On 1 Or 2 Big Bumps = Bad Day
Old Nov 13, 2004 | 06:57 PM
Well you're the only one who thinks Progress springs are toO much drop... whatever... its your opinion... just thought you had more to back it up with... peace.
Old Nov 14, 2004 | 08:03 AM
irish44j's Avatar
retired moderator
1. are you sure the spring in question is not UPSIDE-DOWN? They are similar (but not the same) diameter top and bottom and someone not paying attention could install it upside-down.
2. did you put the spring isolators back on? I know some people don't, but you should! Without them, you will probably have noise.
3. everything torqued to spec?
Old Nov 14, 2004 | 08:04 AM
irish44j's Avatar
retired moderator
uh oh, Joel you've had them on a week now and already getting defensive
no such thing as "too much" or "too little" drop....each spring has it's own advantages in both ride and looks and its own disadvantages.....
Old Nov 14, 2004 | 11:29 AM
Josh...
I was just challenging the guy to see how he arrived at this conclusion that Progress springs are too much... I woulda done it whether I had the springs or not, I just like to hear the evidence and reasoning when people make comments like that. Besides... if I started ranking on your Maxspeeds or Home Depot mods, I'm sure you'd do the same, actually, I have seen ya do the same... and more...
Old Nov 14, 2004 | 04:36 PM
Weasel's Avatar
Do you still have the boxes for the Illuminas? What's the part number for the rear shocks? If it's BU2905 you have a 4th gen rear shock.
Old Nov 14, 2004 | 06:50 PM
BIGMAX19's Avatar
I called tokico and they told me that from 99 - 03 the rear shocks are all the same. tokico told me that maybe its the spring that is two wide.
housecor.... did you ever hear a clicking noise once in a while coming from your rear shocks and did the springs fit perfectly on the perch of your alumina's?????
The noises that i hear is not coming from the front springs those are perfect but its coming from my driver side door and the rear left shock. I heard the same door noises when i had my 4th gen max and it was also lowered...
Old Nov 14, 2004 | 07:17 PM
Originally Posted by Man74
...your alumina's?????
Sorry, don't mean to be picky, but they're spelled "Illuminas" I believe...
Btw, thanks for the springs, they're working out great....
Old Nov 14, 2004 | 09:02 PM
BIGMAX19's Avatar
uuuhhhh thanks and no problem, thanks for buying them.
How is the fitment on your rear shocks and do you hear any noises at all????
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
