Begin modding
Old Nov 3, 2004 | 11:54 AM
JustinMKN's Avatar
Begin modding
I just landed a new job, looking to start modding my Maxima, I've put in a nice woofer that takes up my trunk so now I'm looking for other things. Anyone have some suggestions? I'm more for gadgets and glamor then I am for performance. I've got a 2000 GLE. I'd perfer cheap, mods then more expensive later on. Perhaps changing interior lighting, gauges, something sharp. Any suggestions? I'm looking to do everything my self with friends so if people know where I can get ahold of picture examples that'd rock.
Thanks!
Old Nov 3, 2004 | 11:59 AM
NYC TAR's Avatar
DVD/ Navi Head unit looks nice and sharp inside.
Old Nov 3, 2004 | 12:02 PM
ISELKARS2's Avatar
Thanks!
Hey buddy, welcome to the "ORG" Go to the FAQ & TSB section and you'll get some great ideas! Good luck-most of the folks on here will help you out-just try doing some of your own research first, then if you get stuck, just ask!
Old Nov 3, 2004 | 12:04 PM
NmexMAX's Avatar
dot dot dot ...
Not sure, but from what I've seen, most of us are more into performance mods rather than "gadgets and glamour" , just an observation that I've noticed on here . .
Old Nov 3, 2004 | 12:31 PM
scopium
get chrome gauge rings..lol and make your ignition light blue
Old Nov 3, 2004 | 12:37 PM
PhxBlue's Avatar
MK3 Supra and Focus ST
The Maxima is a friggin 4x4 and handles like Jello in stock form, so you must deal with that problem first with Wheels/tires, lowering springs/struts... Then get a strut brace and a sway bar. Everything else is less important.
Old Nov 3, 2004 | 12:39 PM
JustinMKN's Avatar
To many to pick from
I've seen many mods in FAQ. I guess I'll chip away at a few of those. Your right though most of the time people are talking about performance upgrades, however they have done tons of visual upgrades too. Just noone seems to talk about it. I would love to get a DVD/Nav system, they're bad@ss. But I'm to affraid it would get ganked.
Old Nov 3, 2004 | 12:48 PM
XGaSpAcHo
get AE door sills from courtesyparts.com. easiest mod ever and you notice it every time you get into the car.
Old Nov 3, 2004 | 12:49 PM
PhxBlue's Avatar
Actually I never notice mine anymore. I guess you get used to them and forget about em. The one thing I do notice all the time is my wheels and BBK.
Old Nov 3, 2004 | 01:35 PM
XGaSpAcHo
those are hot wheels man
i think the FSB will probably be my next mod. is that difficult to do? i mean do you need to tighten the bolts with a certain amount of pressure or just tighten as hard as you can?
is your grille painted or do you just have a black mesh one? i can't really tell from the pic.
Old Nov 3, 2004 | 02:24 PM
Puppetmaster's Avatar
I believe you're referring to the FSTB, front strut tower brace.... all ya do is remove the 3 bolts on each strut tower, stick the FSTB on, bolt the outer 2 first, adjust the nuts on the FSTB to make sure the brackets sit flush and the brackets on the other side fit, and then secure the last bolt and you're done. I don't think these should be that tight... I'm guessing around 40-50 lbs is enough...
Old Nov 3, 2004 | 02:57 PM
XGaSpAcHo
yeah that's what i meant. sorry i was typing too fast. what do i need in order to make sure i'm applying the right amount of pressure to them?
do you really notice that much of a difference?
Old Nov 3, 2004 | 03:01 PM
irish44j's Avatar
retired moderator
Thanks!
if you're looking for cheap stuff, check out my cardomain site.....a bunch of fairly inexpensive DIY stuff in addition to "real" real mods....
www.cardomain.com/id/irish44j
I don't recall authorizing you to use the Leprechaun
Old Nov 3, 2004 | 03:43 PM
Bluesbrekr's Avatar
Doctorate in Detailing
IIRC 38 - 42 lbs. is the recommended torque for the FSTB bolts.
Old Nov 3, 2004 | 03:56 PM
Thanks for the correction, BluesBrekr....
Old Nov 3, 2004 | 04:51 PM
XGaSpAcHo
what do you need to check the pressure you're applying when tightening the bolts?
Old Nov 3, 2004 | 05:57 PM
ISELKARS2's Avatar
A thousand apologies hasib!!!
Old Nov 3, 2004 | 07:17 PM
Maxima112's Avatar
Curb Rash Repair 100 a wheel
expensive: rims/tires and a drop and maybe a stillen kit
mid expensive: HIDs w/ DDEs, strut bar, sway bar
Cheap Stuff: AE door sills, paradox gagues, hyper white bulbs, clear corners, fog light bulbs, tint
that my 2 cents.
Old Nov 3, 2004 | 07:22 PM
ZIPPIN's Avatar
Mauja He Mauja
2k2+hids, DDE's, fog hid kit, chrome guage rings, a/e pedals, molded dash kit, Se guages, dvd+screen, interior bulbs..
it depends on how much MUAAA you have to do this...
Apr 16, 2020 05:15 AM
Mar 12, 2020 12:06 AM
REDinLV
Sep 28, 2015 12:31 AM
Sep 27, 2015 08:37 AM
