e brake light won't go out
Old Nov 6, 2004 | 09:07 AM
jklx86's Avatar
i was driving this morning, and i noticed that the brake light was on. the handle's all the way down, does anyone else have a problem with this???
Old Nov 6, 2004 | 09:31 AM
BlackBIRDVQ's Avatar
drag racing is for wussies
check the level of your brake fluid- maybe you don't have enough fluid in the master cylinder brake resevoir and the light came on ? there is a sensor in that little resevoir. Most of the time when the fluid gets low it means that you need new brakes- pistons come out too far and it takes more fluid to push them, so the fluid gets low and POP here comes the light. Inspect your pads.
Old Nov 6, 2004 | 03:29 PM
irish44j's Avatar
retired moderator
if that isn't it (which it probably is...), perhaps adjust the ebrake lever a little looser so it's not contacting the ebrake light button. the adjustment is at the base of the front of the ebrake handle assembly.
Old Nov 6, 2004 | 08:55 PM
jklx86's Avatar
the light went away...i guess it was just temporary, because i just turned on my engine couple hours later, and the light dissappeared. thanks anyways
Old Nov 6, 2004 | 09:39 PM
FanaticMadMax's Avatar
It's probably the sensor switch on your e-brake that probably got stuck.
Old Nov 6, 2004 | 11:10 PM
wngan9447's Avatar
Chicken Feet Croo!
you should check the master cylinder anyways to be sure
Old Nov 6, 2004 | 11:42 PM
next time you come to a abrrupt stop the brake fluid will slush in the reservoir and the light will come on. Reason it probably went out is that you caliper pistons must have returned back a little bit and some of the fluid returned back into the reservoir and turned off the light.
Old Nov 7, 2004 | 06:13 AM
bostonmax84's Avatar
The same thing happened to me with the ebrake light going on and off. I ended up needing new brakes, thats why the light stayed on, so check your brakes just to be sure.
Old Nov 7, 2004 | 05:48 PM
MY2000MAX's Avatar
Thats exactly what happened with me. After getting new pads, all was good again.
Old Nov 7, 2004 | 10:27 PM
bustedmax's Avatar
similar problem
After I changed my rotors, pads and lines I noticed my e-brake light staying on. Any ideas on how to rectify my situation?
Old Nov 7, 2004 | 11:32 PM
MauiMaxima's Avatar
You know I had that same problem after doing doughnuts in the parking lot after some snow. It went away when I clean out my rotors and resurfaced them.
tsi6001
Oct 3, 2022 10:23 PM
JMag90
Aug 25, 2015 09:17 AM
Nismo_Guy89
Aug 24, 2015 09:49 PM
Samedi
Aug 13, 2015 04:05 PM
