What light bulb numbers for climate control, radio, power windows, and instr cluster?
Old Nov 8, 2004 | 06:40 PM
Whtmax'01's Avatar
I want to change the light bulbs in all these areas to a different color, so anyone know the type of bulbs for each location. I think for instr cluster its type 74, but what about other locations ?
Old Nov 9, 2004 | 06:26 AM
Bl_asd's Avatar
you have to use LED in other locations. Use 3mm LED in radio and 5mm LED in window switch and climate control.
http://www.petah.org/maxima/maxima.htm
Old Nov 9, 2004 | 06:30 AM
† ErV †
I'll say it again.. the instrument cluster color is not sensitive to the bulb. It has a transparent layer built in that gives it the color you see. The bulbs are in fact yellow (standard wire bulb, no coating). The way to change it is to use high powered blue leds so you basically override the built in white layer..
MikesChevelle
Mar 2, 2021 11:32 AM
dr3am
25
Oct 22, 2015 08:53 PM
homeyclaus
Sep 3, 2015 06:15 PM
