Top Speed in Gears
Old Nov 10, 2004 | 10:56 AM
Stev02
Top Speed in Gears
Ok, ever since I modded my car with a full exhaust (y-pipe, b-pipe, high flo cat) and intake (WAI pop charge), it seems as if my top speeds have changed a bit.
All I noticed was my third gear tops out at 98 MPH. I also just glanced over to see that my 2nd gear tops a little over 60 MPH. The owner's manual says 2nd is around 55 MPH and 3rd is about 88 MPH.
Is my tach or speedo off? I'd like to know. If you have the same mods (or close to) what do you top at?Thanks for the insight.
-Stevo
Old Nov 10, 2004 | 11:03 AM
NmexMAX's Avatar
dot dot dot ...
It's the owners manual, tehy have safety, non performance in mind, and if you mean you have different speeds relative to different RPM's, you're wrong.
Even with differnt tire sizes, your speed/rpm relation will never change, even if your true speed is off due to your tires because the speed/engine rpm are calibrated and will enver change unless you get different gear ratios and swapped them in, or final drive of course too.
Old Nov 10, 2004 | 11:06 AM
Stev02
OK so what you're saying is it's normal to hit 98 in 3rd? If that's the case, my question is solved.
Old Nov 10, 2004 | 11:08 AM
vortechpower's Avatar
I can see 98 in 3rd. If you had a mevi wouldnt that change the speed in a specific gear???
Old Nov 10, 2004 | 11:16 AM
NmexMAX's Avatar
dot dot dot ...
A MEVI wont change it, just make you get there faster, only mods that will change that are swapped gear ratios or an increased rev limiter, NOTHING else.
Old Nov 10, 2004 | 11:26 AM
Matt_01SE_20th's Avatar
that sounds about right i hit about 62 in 2nd and about 97 in 3rd. 01 5-speed AE. im not sure if the limited slip has a slightly different ratio or not. i shouldnt, but it might.
Old Nov 10, 2004 | 01:07 PM
Larrio's Avatar
The Definitive AE Master
if you put more power down with mods/bolt ons, why wouldn't you shift at a higher speed than you did stock?
how do you think cars trap higher speeds at the track? Your rpm ratio will never change unless you change out gears. Your speed in each gear will varying depending on the amount of power you put down.
Old Nov 10, 2004 | 04:44 PM
what he said.
Old Nov 10, 2004 | 05:21 PM
Jaws's Avatar
You wouldn't shift at a higher speed because you would be over-reving the engine. Your speed in each gear will not vary depending how much power you are putting down, because as you mentioned it is a fixed relationship between engine speed and road speed. With more power however, the ability of the car to get to redline faster increases, which is why the car is quicker.
Old Nov 10, 2004 | 07:31 PM
BlackBIRDVQ's Avatar
drag racing is for wussies
66MPH 2nd- 100 in 3rd, 125MPH in 4th, 159MPH in 5th.
Old Nov 10, 2004 | 07:40 PM
kratz74's Avatar
HP doesn't change your gearing. You will hit the same top speed in eahc gear no matter how much hp you have. You'll just get there faster.
Old Nov 10, 2004 | 07:42 PM
Loe max's Avatar
I didn't realise that the overrall gearing is shorter than a 3rd gen 5speeds, awesome.
Old Nov 10, 2004 | 11:11 PM
Larrio's Avatar
okay there we go, overall time to get to those speeds are faster. thanks for correcting me
Old Nov 11, 2004 | 06:11 AM
Stev02
Thanks everyone
Old Nov 11, 2004 | 10:42 AM
merovi's Avatar
i ahve stock 2k and i have got 60 mph in 2nd gear only because i saw it in a video and didnt' believe it...but hey it worked..and im' not modded so there ya go.
James92SE
142
Jan 2, 2024 09:23 AM
captchaos
Mar 15, 2016 12:18 PM
Maxxx10
Sep 13, 2015 03:16 PM
jcvgn
Sep 10, 2015 08:03 PM
pjgreek
Sep 9, 2015 09:30 PM
