RSB Install time
Old Nov 11, 2004 | 06:44 PM
3Pedals_6Speeds's Avatar
RSB Install time
If I can get it up on a lift so I can walk underneath it, how long should I expect it to take?
Old Nov 11, 2004 | 06:59 PM
BP's Avatar
BP
taking the rear wheels off will make it easier. it should take about 30 min. be sure to check everything after a day or two of driving.
Old Nov 11, 2004 | 07:18 PM
Matt_01SE_20th's Avatar
i just backed mine onto ramps and was able to do it in like 30-45 minutes.
Old Nov 11, 2004 | 07:28 PM
ZIPPIN's Avatar
Mauja He Mauja
could be wrong. but i read that the suspension should be load free for this????
Old Nov 11, 2004 | 07:31 PM
dblrr900's Avatar
I jacked mine up too. I took the wheels off and put them under the car and then rolled under there. I did it in about 30-45 minutes as well. It wasn't real tough, just have to make sure it is in the right place or you will get the banging of your life from the rear end.
Old Nov 12, 2004 | 06:10 PM
midnightmax01's Avatar
does anyone other than stillen make a rear sway bar for the 01 maxima ?
cause if so i might have to buy one.
Old Nov 12, 2004 | 06:21 PM
dblrr900's Avatar
Adco RSB. Call Catman they have them.
Old Nov 12, 2004 | 06:29 PM
Maxima Dan's Avatar
Back before I bought jack stands it took me a couple of hours to install my Stillen RSB. Total PITA. If you can get it off the ground and both rear wheels off it should only take 30min or so.
01SE02SER's Avatar
Faster than a speeding bullet...
Originally Posted by midnightmax01
does anyone other than stillen make a rear sway bar for the 01 maxima ? cause if so i might have to buy one.
Check out my post in this thread...
http://forums.maxima.org/showthread....16#post3221016
Peace.
Old Nov 12, 2004 | 08:02 PM
SoonerFan's Avatar
Cletus
it can be done in 10 minutes...with a lift, the correct tools, and someone who knows what they are doing
Old Nov 12, 2004 | 08:07 PM
Puppetmaster's Avatar
You should be able to get Craftsman jack stands at Sears for $20 a pair.... maybe even less if ya can find some generic ones.... its worth the investment esp if you're gonna be doing more work on your car down the road...
Old Nov 13, 2004 | 05:06 AM
Audtatious's Avatar
Bandwagon Lover
I did mine with ramps. Load is not an issue since the rear bushings allow movement of the rear beam anyway.
http://www.win.net/audtatious/audio/tech/addcorsb.html
SmokinMax02
18
Sep 11, 2015 12:25 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
Team STILLEN
Aug 10, 2015 04:29 PM
