Tunning Question
Old Nov 14, 2004 | 08:31 PM
I30swimmer's Avatar
Tunning Question
Is there any way to adjust how rich or lean you run the engine? Can i just adjust a screw somewhere, or do i acctually need to buy a computer that will do adjusting?
Old Nov 15, 2004 | 06:04 AM
I30swimmer's Avatar
no one knows?
Old Nov 15, 2004 | 09:06 AM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
you need to buy an apexi SAFC II. check their website for more info. there is nothing on the car that can adjust it but the consult 2 might able to make changes to the ecu that would affect a/f. but then you would have to know someone at a dealer.
Old Nov 15, 2004 | 09:23 AM
2k2kev's Avatar
It's chrome alright...
read:
http://www.apexi-usa.com/electronics_safc.asp
Old Nov 15, 2004 | 09:24 AM
Matt_01SE_20th's Avatar
if you get an adjustable fuel pressure regulator, you could run higher pressure and richer but teh computer will try to lean it out. my FPR was at to high a pressure and i started getting engine codes of "bank 1 rich mixture". at a certain point the ECU cant lean it out anymore, and you can run rich. i dont recomend this for daily driving because the MPG sucks. it does give your car a nice kick though
Old Nov 15, 2004 | 09:27 AM
2k2kev's Avatar
Actually, why do you want to do it?
Old Nov 15, 2004 | 08:07 PM
irish44j's Avatar
retired moderator
if you can find the carburetor, turn the fuel feed screw to change the fuel/air mix.
oh wait...we don't have carburetors. oh well.
Old Nov 16, 2004 | 07:28 PM
I30swimmer's Avatar
well when the car is running Lean... and has the check engine light on because of it.. how would i make it rich again?
Old Nov 17, 2004 | 06:23 AM
sloppymax's Avatar
you have to replace the part that is not functioning correctly. some 350z guys ran lean with headers and full exhaust but from what i heard, even that was only slightly. if you are running lean the most likely your maf is bad or a bad primary (upstream) o2 sensor.
Old Nov 17, 2004 | 09:16 AM
00Max00's Avatar
my max always has some pinging underhood what i think was caused by running lean, but no code whatsoever.
Old Nov 17, 2004 | 09:40 AM
2k2kev's Avatar
Did you pull the codes or are you guessing?
How about taking it to a dealer and asking them to diagnose it and give an estimate on what to fix and how much, then deciding if it's worth getting done. If you somehow figure out a way to richen it up, you're only hiding the problem, not fixing it.
Old Nov 17, 2004 | 10:48 AM
sloppymax's Avatar
is it P0171 or P0174?
Old Nov 17, 2004 | 01:17 PM
MaximaMan77's Avatar
DTC No. P0171 0171 (Bank 1); P0174 0174 (Bank 2)
Trouble diagnosis name: Fuel injection system too lean
DTC Detecting Condition: Fuel injection system does not operate Properly, the amount of mixture ratio compensation is too large.(The mixture ratio is too lean.)
Possible Cause:
Intake air leaks
Heated oxygen sensor 1
Injectors
Exhaust gas leaks
Incorrect fuel pressure
Lack of fuel
Mass air flow sensor
Incorrect PCV hose connection
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
