Sunroof Problem!
Old Nov 18, 2004 | 08:55 AM
naerok's Avatar
Sunroof Problem!
Something is wrong with my sunroof. The one-touch feature doesnt work and the up/down button actually slides the sunroof back and forwards. Also, when i try to use the sunroof, it stops like every 6 inches. I have no idea what is the problem...
any suggestions?? please help.
thanks..
Old Nov 18, 2004 | 09:12 AM
Y2KSilvahSE's Avatar
I have the exact same problem. Resetting the ecu (disconnect battery) works for only 3 to 6 days, then it does the same thing all over again. I have been told that lubing up the channels, then resetting the ecu will fix it, but I have not had the time to try that yet...
Old Nov 18, 2004 | 10:25 AM
naerok's Avatar
thanks.. i will give it a try..
Old Nov 18, 2004 | 11:15 AM
maseo77's Avatar
My sunroof does the same thing after resetting the battery, works for a few days then acts up all over again.
Old Nov 18, 2004 | 11:28 AM
naerok's Avatar
it seems to be a somewhat common problem.... what else have you tried???
Old Nov 18, 2004 | 12:11 PM
ddpack's Avatar
Turn key on. Push sunroof down button, make sure it's all the way down. After it's all the way down, continue pushing for 3-4 seconds, it should reset. Mine was the same way and this worked.
Old Nov 18, 2004 | 12:23 PM
bert's Avatar
When mine did that a new sunroom motor fixed it. (the control board is mounted as a unit to the motor).
I have also fixed a similar problem by opening the roof all the way, removed the key, closed the sunroof, removed the key, tilted up the sunroof, removed the key, closed the sunroof, remove the key.
Old Nov 18, 2004 | 12:53 PM
naerok's Avatar
im gonna try this first before i reset the ECU. thanks ddpack!
Old Nov 18, 2004 | 01:21 PM
Loe max's Avatar
Unfortunately, my 00 did this also. My one-touch feature stopped working so I disconnected the battery, put it back on, and it never reappeared again.
Old Nov 18, 2004 | 02:03 PM
Fezzik's Avatar
well mine did this and all i had to do was turn the car off and on a few times. Sorry i meant switch key to on and take out of ignition and then put back in and on a few times. at the level where the sunroof is at currently. Fixed it
Old Nov 18, 2004 | 02:08 PM
LA02MAX's Avatar
mine wouldnt even open at all the other day, it would just tilt and re-close. I kept on trying and it finally worked, but thats the only problem ive had so far with it....hope nothin like this happens to it.
Old Nov 18, 2004 | 02:16 PM
GBAUER's Avatar
Search through the past forums. I had the same problem and reset the computer the way it said in the forums rather than just disconnecting the battery and haven't had a problem in two months.
Old Nov 18, 2004 | 02:17 PM
ddpack's Avatar
There is a TSB on this problem that suggests doing the holding down routine I mentioned!
Old Nov 19, 2004 | 05:44 AM
naerok's Avatar
do you have a link to the TSB???
Old Nov 19, 2004 | 05:48 AM
ihavea5spd's Avatar
he has a 2001. the reset procedure doesn't apply to his car. i;ve posted the fix to this problem about 25 times. shouldn't be tough to find.
Old Nov 19, 2004 | 11:39 AM
naerok's Avatar
i'll search for it thanks.. i should have looked at tsb's before i posted. i feel like a newbie for real....
Mar 12, 2020 12:06 AM
Blkkn8
Sep 15, 2015 06:57 PM
Vequity
Sep 10, 2015 05:26 AM
mikebla
Sep 3, 2015 05:37 PM
