Low RPM idle.
Old Nov 19, 2004 | 07:20 AM
Greek to the Max's Avatar
Low RPM idle.
My 2003 6speed max is idling a little low i think, and fluttering ever so slightly. Not enough to notice without being picky. 37,000Km's. Any ideas anyone?
Old Nov 19, 2004 | 07:23 AM
GreenSeMax's Avatar
clean the throttle body, change the pcv valve, air filter, shouldn't be plugs at this point, not enough miles, but if you run bad gas it might be. start with a throttle body cleaning and pcv valve for a cheap solution. if it's not resolved, your problem may be deeper than that.
Old Nov 19, 2004 | 07:45 AM
I have a intake. The filter needs changing. What is stock idle?
Old Nov 19, 2004 | 08:05 AM
GreenSeMax's Avatar
~650 +- 50rpm
Old Nov 19, 2004 | 08:13 AM
00Max00's Avatar
m/t: 625+-50
a/t: 700+-50
Old Nov 19, 2004 | 08:34 AM
Originally Posted by 00Max00
m/t: 625+-50
a/t: 700+-50
They mentioned 725. Anyhow, Im gunna replace filter and clean TB.
Old Nov 19, 2004 | 08:35 AM
A33 VQ30DEK's Avatar
seafoam that bish too haha
Old Nov 19, 2004 | 01:28 PM
MaxedOut's Avatar
ahaha my idle is 350-450 hahahah
is having a bad idle bad? i dont have tiemn to clean my TB
Old Nov 19, 2004 | 05:18 PM
nailz420's Avatar
550 is the normal idle
Old Nov 22, 2004 | 07:21 AM
Different info. Well its not so much the idling as is the shivering i feel from the car. Is it a bad mount? slight misfire? I dont know. Its at the dealer today, Im sure they will blame everything on teh intake.
Old Nov 22, 2004 | 11:11 AM
Dealer said the idle was fine. everything checked out normal. I said, what about the shaking feeling. They said they wouldnt check that because the car has after market intake. I'm not surprised.
Old Nov 22, 2004 | 02:38 PM
NYC TAR's Avatar
^^^ never clean the TB on 02 -03 max because 99.9% you will mess the TB plate. either it need to program by the dealer using the consult II "Idle Air Volume Learning Procedure(Throttle Position Learning Procedure)". The other chance is bending the TB plate by using force. Some org, member aready made this mistake.
Old Nov 22, 2004 | 02:39 PM
NYC TAR's Avatar
^^^ never clean the TB on 02 -03 max because 99.9% you will mess the TB plate. either it needs to be program by the dealer using the consult II "Idle Air Volume Learning Procedure(Throttle Position Learning Procedure)". The other chance is bending the TB plate by using force. Some org. member aready made this mistake.
Old Nov 22, 2004 | 02:40 PM
NYC TAR's Avatar
^^^ never clean the TB on 02 -03 max because 99.9% you will mess up the TB plate. either it needs to be program by the dealer using the consult II "Idle Air Volume Learning Procedure(Throttle Position Learning Procedure)". The other chance is bending the TB plate by using force. Some org. member aready made this mistake.
Old Nov 22, 2004 | 03:45 PM
I dont understand. You can't clean the throttle bodies on these cars? What plate are you refering to?
Old Nov 22, 2004 | 04:27 PM
NYC TAR's Avatar
sorry about the repost
you can clean it, but You run a bigger risk of bracken the TB. basically the plate is very fragile
The previous Max (EX 01-00) throttle body plate are controlled by using wire and spring (throttle plate control how much air enter the engine) the new Max 02-03 throttle plate are controlled by computer sensors and mechanical. every time you shut the car the plate stay in the same spot, but when you forced to plate to open, the spec position of the plate is town off, because you moved the plate around when cleaning. this will cause a high idle and you will need the dealer to get the plate in right spec with the computer they have (consult II) .
Old Nov 22, 2004 | 09:21 PM
adithius's Avatar
You can try and loosen the timing belt (very lightly) about 1/8 inch. That should get your revs up a bit. If your belt squeels, tighten it a little. Easy fix
Old Nov 23, 2004 | 04:57 AM
Idles are fine. 7 and change. They did some air volume test and relearn process. Then istalled a new apexi filter. Man, the MAF Sensor plenum was dirty, can that be cleaned? Can teh dealer clean teh throttle body?
Old Nov 23, 2004 | 06:33 AM
resurrectedmax's Avatar
enthuzed.........
i'm getting the same low idle shiver also. i'll have my nissan tech check it. he's family!
Old Nov 23, 2004 | 06:44 AM
whic dealer brampton boy?
Old Nov 23, 2004 | 06:57 AM
enthuzed.........
avenue nissan, toronto.
why you ask?
Old Nov 23, 2004 | 07:01 AM
just keep me posted on your discover......i think the problem may be the maf....
Old Nov 23, 2004 | 07:02 AM
enthuzed.........
will do, we may be looking at it tonight, if not tomorrow night
Old Nov 24, 2004 | 11:20 AM
NYC TAR's Avatar
just read this and see what I mean. Just don't clean it, You run a bigger risk braking the thing than cleaning it, http://forums.maxima.org/showthread.php?t=356816
Old Nov 24, 2004 | 11:42 AM
WildmanAL's Avatar
I'm a victim of this....... I took the damn thing off and it shorted out. Thank got for powertrain warranty.
There has been an org member that did clean his 2k3 successfully though. He disconnected the neg battery terminal and just sprayed the cleaning into the TB. With this thing being computer operated so many things can go wrong. As of now I don't know too much about exactly how they work or why exactly mine shorted out, but I wouldn't risk it. My throttle body wasn't even dirty.
$1000 was not worth cleaning this much of crud off the back of my TB.
I've seen a lot worse and it really wasn't that much stuff.
Old Nov 24, 2004 | 11:52 AM
Ok, but what about the intake plenum and MAF plenum?
Old Nov 24, 2004 | 11:56 AM
NYC TAR's Avatar
MAF is also a biger risk, but a new 2k1 MAF is only $100.
Old Nov 24, 2004 | 11:57 AM
thats the price for my 03?
Old Nov 24, 2004 | 12:10 PM
NYC TAR's Avatar
^^^ some other guy from NJ bend his TB plate when cleaning it, but he just bought used TB form org. members wrecked car. To you the truth, I cleaned the TB last week and got P 0517 ( hi idle). It took my friend a hour to program it back to spec with the consult. right now I don't have the SES light, but car jerk when comming to compete stop ( the rpm rise up and down) I think the tranny is just down shifting down shifting. plus he erase the ECU, may take time to repogram it back ( tranny shift piont )
The maf for 02-03 are $500 each, but you can use 2k1 maf for $100.
Old Nov 25, 2004 | 06:09 AM
Explain how I can use a 2k1 MAF on my 03. thanks.
Old Nov 25, 2004 | 08:35 AM
NYC TAR's Avatar
you just take your temp sensor form the 02 03 MAF and put it in the 01 maf. If you don't won't mind having SEC light you can just do plug and play.
Old Nov 25, 2004 | 08:41 AM
sounds like a ninja tactic.
Unclejunebug
Apr 2, 2016 05:42 AM
ef9
Oct 4, 2015 08:43 AM
Need help
23
Oct 2, 2015 08:56 AM
