question about belts
I just recently had my alternator replaced, and now once in a while i get this squeaking noise from one of my belts/pulleys. I figured that they probably didnt tighten the belt good enough, but I took the car back, and the guy says its probably because the belt is old and needs to be replaced. My question is, does a worn out belt make a squeaking noise before its about to go out, or is it most likely just a loose belt that they dont want to admit to?
thanks for your time.
i think nissan recomends 60K mi. i have 74 on mine and i am on original belts. i am replacing them when i put the UDP on. i cant get the old crank pulley off though. i went to a performance shop and they said it would cast $65/hour and take 3 HOURS. i could do it in 1 if i could get that damn bolt off. they are sqeeking really bad when its humid out.
one reason could be that they are slipping (even if the belts are tight enough)
try belt dressing. its a spray for the belts. it conditions the rubber to get better grip and make the belts last longer
Originally Posted by Ammi
That's only a temporary fix. Noise will come back.
no its not. when i got new belts they were making noise so i sprayed them. that was a year ago and havent had a sound.
i have 69k and my belts squeal all the time when i drive through water and at start up in the cold. i was told $265 to replace drivebelt, and that they dont need to be tightened because our cars have self tighteners. a while back i saw someone on the forum had nissan coupons for $99 belt change but that was a few months ago...maybe they will do it again.
trsandrew
Apr 8, 2016 06:45 PM
Unclejunebug
Apr 2, 2016 05:42 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
