HELP! Front AC power adapter does not work!
Old Nov 19, 2004 | 05:47 PM
NYghettoGLE's Avatar
my front ciggarette lighter adapter does not work..........is annoying me like never before.
i'm constantly on my cell phone while i drive (kinda sad, but i use my max for cell phone deliveries) i can't charge my phone in the front socket.
i gotta use my back socket but is so darn unconfortable and annoying, grrrrrrr.
i already changed the fuse located on the lower left side of the drivers side, but no luck.
what could be the problem?
Old Nov 19, 2004 | 07:07 PM
Matt_01SE_20th's Avatar
pull of the plastic molding around the shifter and see if the connection came lose. this is all i can think of, unless you screwed up the socket somehow.
Old Nov 19, 2004 | 07:28 PM
SoonerFan's Avatar
Cletus
just an idea but have you tried plugging something else into it? i have had alot of car chargers go bad
Old Nov 20, 2004 | 01:03 AM
crispykid717's Avatar
Bigger than Jesus
I have the exact same problem as you. I've been thru 3 different chargers and none of them worked. My fuse is not blown either. Finally I just said f' it and used the one on the rear cup holder.
Old Nov 20, 2004 | 10:18 AM
nyautostyle's Avatar
check to see if there is power running to it, might be a short or a disconnection. Could always install new one if u go that far, its only like 10bucks... but im sure you'll be able to fix it
MikesChevelle
Nov 23, 2024 11:17 AM
maxinout93
Oct 27, 2015 01:29 PM
jerrod99_se-l
Aug 27, 2015 08:27 PM
kenc15
Aug 5, 2015 08:29 AM
kjm900r
Aug 5, 2015 07:14 AM
