Clutch noise
Old Nov 21, 2004 | 10:24 PM
sooner02r1's Avatar
Clutch noise
I have an '02 6 speed, and there is a squeaking sound coming from the clutch. When I first heard it I thought it was a belt, but when I checked under the hood, I found that it is the little bracket where the clutch cable goes into the trans. housing. It only squeaks when the clutch is fully engaged at idle. You can put pressure on the bracket with your hand or put pressure on the clutch pedal and it will stop. Has anyone experienced this or does anyone know how to fix it?
Old Nov 22, 2004 | 07:18 AM
Puppetmaster's Avatar
This was discussed pretty recently here... or at least it was a similar issue...
http://forums.maxima.org/showthread.php?t=347536
Old Nov 22, 2004 | 09:16 AM
sooner02r1's Avatar
Yeah I'm having the same problem discussed in that thread.
Old Nov 22, 2004 | 11:09 AM
Yeah cool, just use that thread then, instead of starting a new one... those guys will probably be able to give ya more input and comments....
user 11122324
42
Jul 18, 2022 03:35 PM
aw11power
Oct 10, 2021 04:57 AM
D Mason
Jun 21, 2016 04:43 AM
uttadms31
Sep 30, 2015 05:24 AM
