SES Light on after cleaning Throttle Body
Old Nov 23, 2004 | 06:44 AM
UGAd13's Avatar
I used the throttle body cleaner in the aerosol can over the weekend and now the SES light is on. I did everything according to the directions, however, the engine did stall on me once while I was spraying the cleaner into the throttle body. After the engine stalled, I restarted the car and continued to use the cleaner. I can't rememeber if the light came on right then or after I was completely finished.
I disconnected the negative battery cable last night and reconnected it this morning and the light is still on.
Has anyone experienced this before? If so, what was the fix? The car seems to be running fine, just that the light is on. Can most auto part stores (Auto Zone, Advanced Auto Parts) pull the code and if so how much is it to get the code pulled?
Thanks for the help.
Old Nov 23, 2004 | 06:54 AM
Ammi's Avatar
350 Detroit Muscle
Different cans have different directions of cleaning TB. I would have recommended you not to leave your car on while you clean your TB.
Old Nov 23, 2004 | 11:13 AM
gsumax's Avatar
go to autozone, they dont charge anything to pull a code.
Old Nov 23, 2004 | 11:43 AM
NmexMAX's Avatar
dot dot dot ...
You should've d/c the battery before you worked on it to trick the E-throttle.
Old Nov 23, 2004 | 01:16 PM
kcowden's Avatar
With the 02-03 maxes disconnecting the battery won't reset the ecu. There is a procedure on how to reset the ecu here at www.technosquareinc.com
Old Nov 23, 2004 | 01:26 PM
GaMax97GLE's Avatar
I couldn't find a reset procedure there.
Greg-
try here: http://maxima.theowensfamily.com/ecu.asp
Old Nov 23, 2004 | 01:32 PM
BP's Avatar
BP
i've left mine disconnected over night and it reset the ecu just fine. (got an ses from the drop resistor mod)
either way, if you reset it and it comes back on that means the problem is still there and you should get the codes pulled.
Old Nov 23, 2004 | 01:35 PM
NmexMAX's Avatar
dot dot dot ...
I know, but this will allow the Ethrottle not to detect the moving of the throttle plate during the time you clean it.
Old Nov 23, 2004 | 01:43 PM
UGAd13's Avatar
The "Ethrottle?" I guess that's why I couldn't find a cable to move the value open/close. Do you have any more info on that, or know of something I could read b/c I would like to know more about the Ethrottle. Thanks.
Old Nov 23, 2004 | 01:52 PM
NmexMAX's Avatar
dot dot dot ...
More widely known as throttle by wire on 2k2+.
Is that why you had th car on while revving and cleaning your TB?
The Pathfinder has a VQ35 with a conventional cable, as I'm sure otherVQ35's may as well, but the Pathfinder is the only one I know of off hand.
I myself don't know much about it, so I wouln't be of much help.
I will tell you what I think.
First off, for manual tranny people it's hard to launch because your foot is not directly connected to the throttle, as there is some delay in the response.
I've also read that Pontiac, doesn't mean Nissan does it, actually electronically tailors the throttle slightly more shut to smooth out shifts on the auto tranny on their new Grand Prix line-up during WOT.
And Technosquare, the company that re-programs ECU's for our cars claims that the flas actually starts closing towards redline to hurt power and discourage us from going to the redline as often s we would like.
Old Nov 23, 2004 | 02:22 PM
s_hinerman's Avatar
The same thing happened to mine and they had to replace my entire thorttle body under warranty. Something about manually moving the butterfly. If you go to the dealer don't mention you cleaned it. Hope this helps
Old Nov 23, 2004 | 03:25 PM
WildmanAL's Avatar
I took off my throttle body to clean it and somehow it shorted out.... thank god it was under warranty or I would be out 1K right now. I suggest to 5.5th gen not to touch their throttle bodies. They're not even dirty yet so why clean it?
You say your max runs fine though........ most people that get the SES had a high idle of 900rmp and that is what the SES light is from (idling higher than expected).
Old Nov 24, 2004 | 05:52 AM
UGAd13's Avatar
Greg-
Thanks guys for the input. I used the procedure in the link above to reset the ECU and the SES light turned off. It took me a couple of tries to get the sequence down, but it finally worked. I guess I dodged that bullet.
Old Nov 24, 2004 | 09:41 AM
s_hinerman's Avatar
Don't be so sure i did the same thing and it came back on about a day later. I hope i am wrong for your sake
vingodine
45
May 21, 2016 12:46 PM
homewrecker
Aug 24, 2015 08:56 PM
Samedi
Aug 13, 2015 04:05 PM
yat70458
Aug 3, 2015 01:16 PM
maxima297
Aug 3, 2015 12:50 PM
