Has anyone ever disassembled fog lamps on a 2k or 2k1? I removed the 2 small screws located on side of each lamp and still having problems disassembling them. As posted on previous post, I am having problems fitting H3 HID's onto these lamps and would like to disassemble them and try a diffrent method of installation.
Thanks,
titot
Thanks,
titot
i'm not sure about the two screws you're talking about, but if you take the lower panel off(splashguard) there is one 10mm/phillips screw that comes out from below, laying on your back is easiest, with the wheel turned to the outside. then the fodlight housing pushes out the front of the bumper cover, be sure to unplug the light socket first, otherwise it'll pull on the wires, and catch the light or it will hit the ground.
Quote:
I already removed the foglight housing from the bumper. I'm trying to disassemble the lamp housing for other methods of HID installation. The two screws that I mentioned above are on housing lens.Originally Posted by GreenSeMax
i believe the lenses are bonded to the body, i don't think the housing can be separated, unless perhaps you can heat them like the headlights.
yea, after you remove the two screws you can heat them like headlights and get inside. I had to do to re-attach the a reflector that shook loose.
If you do it be sure to pry the lens off perfectly straight, dont do one side of the lens then the other, i tried that at first and marked up the outside edge of the lense pretty good.
No need to heat the lights or the housing. After that screw is removed, it takes a good bit of force to push the entire housing of the front of the bumper. Just wiggle it and push with some pressure, it will pop out with no damage to the light, wires or housing.
Quote:
I dont think so, i believe the 2k3's are glass and shaped different....anybody confirm this??Originally Posted by 2K3MAX2NV
will a 2k OEM foglight housing and lens fit on a 2k3?
