1994 Maxima
Old Nov 29, 2004 | 12:18 PM
kevinopp's Avatar
1994 Maxima
Hello,
I have a 1994 Maxima/3.0 Liter Automatic with 212,000 miles. I was leaving work on Friday and started the car like normal. It started ok but when I put the car in Reverse, it died. When I got the car on the highway, it ran fine. And continues to run fine after the car has been driven for a short period of time. It only does this after it has been sitting for more than 8 hours or so. I thought that it may have been the fuel filter so I changed it but that didn't effect the way the car acted this morning. Have any of you heard of this? It will also die when the car goes into drive, or any other gear besides Park/Neutral.
Any help would be appreciated.
Thanks,
Old Nov 29, 2004 | 12:25 PM
NmexMAX's Avatar
dot dot dot ...
Post in the 3rd generation forum, as you are in the 5th genration area. Read the top of the forum label, and it states what year(s) is/are included in the given generation.
Old Nov 29, 2004 | 12:26 PM
paralyse's Avatar
I Miss My Maxima
This should probably be in the 2/3 Gen forum but since you posted it here I will offer a suggestion of checking the throttle position sensor and/or idle air control solenoid/valve. You'll probably have much better luck posting in 2nd/3rd gen.
Goffery2uned
Aug 21, 2015 09:50 PM
Team STILLEN
Aug 10, 2015 04:29 PM
