Y-pipe and check engine light questions..
Old Nov 30, 2004 | 03:55 PM
bigtexan7's Avatar
I had a Y-pipe on my 95 Max and never had a check engine light.
That 95 was an OBD-1 car.
I now have an 01 Max and want to put on a Y-pipe, however it is OBD-II and therefore much more sensitive to the SES light.
Will the lack of catalysts in the Y-pipe cause the SES light to come on from time to time on a 5th gen?
Any 5th gen owners with Y-pipes able to share any experience?
Old Nov 30, 2004 | 03:56 PM
imported_JIC_A33
i put the cattman y on my 02 and never seen a check engine light...
Old Nov 30, 2004 | 07:37 PM
Max20SE00's Avatar
I had the cattman y on my fed spec 2000 and pulled a ses light.
Old Nov 30, 2004 | 10:47 PM
NisMo-Max's Avatar
I have a 5th gen cali 2001 AE with a Stillen y pipe, I got my CeL light!!!
Old Dec 1, 2004 | 06:10 AM
F23A4's Avatar
on my 02 w/Cattman Y-pipe.
Old Dec 1, 2004 | 08:18 AM
2k1seae's Avatar
I have a Cattman Y-Pipe on my 01 AE (6 months ago) and have had no lights and no problems. I also just passed Oregon emission testing last month. BTW I'm Cali spec.
Old Dec 1, 2004 | 08:23 AM
Komax's Avatar
2000 Maxima with Budget Y Pipe...cel came on 2-3 months afterwards.
Old Dec 1, 2004 | 08:38 AM
takkar's Avatar
what kind of CEL are we looking at? And also, would a reset ( disconnect battery) help? Or is something really wrong and has to be fixed?
Old Dec 1, 2004 | 10:56 PM
NisMo-Max's Avatar
Ur looking at an 02 sensor reading a high voltage that the voltage is out of the range of the 02 sensor, you might be able to fix it buy replacing ur 02 sensor or buying an o2 simulator. resetting your batter will not help it will come back on
Old Dec 2, 2004 | 12:19 AM
crispykid717's Avatar
Bigger than Jesus
Ypipe on my '02 for about 6 months now. No CEL and passed emissions too.
Old Dec 2, 2004 | 02:22 AM
Larrio's Avatar
The Definitive AE Master
02+ maximas don't have this problem. Some of the 01 cali spec maximas experience the symptoms described in post#9 by nismo-max. Three possible ways to get rid of it IF the code is P0140 or similar (rear secondary o2 sensors reading high voltage)
1. replace o2 sensor (however it will come back eventually as the y-pipe will cause a excessive high voltage reading again)
2. o2 simulator
3. your ECU may fall in a nissan TSB which fixes a glitch where the ECU keeps reading the o2 within too narrow parameters.
CorollaULEV
30
Aug 9, 2021 08:11 PM
Justinmc760
Aug 23, 2015 03:10 AM
maxinout93
Aug 20, 2015 02:17 AM
beboski
Aug 16, 2015 05:23 PM
Flores94
Aug 11, 2015 12:53 PM
