Need help removing trim
Old Dec 3, 2004 | 01:14 PM
03on18s's Avatar
can somebody write a quick how-to on removing the dash trim in order to change the light that shines down onto the center console? also....is there anyway to change the color of the bulbs in the shifter that light up the gear (i.e. P, R, N, D-3, 1, 2)?
Old Dec 3, 2004 | 06:37 PM
Matt_01SE_20th's Avatar
im not sure if auto is different, but in a manual, all you do is remove the screw from behind teh coin tray and then pull up on the center console. the light is attached to the part you remove. you should see it. like i said, it may be different in an auto.
Old Dec 3, 2004 | 06:38 PM
Manaz101's Avatar
Maybe this will help you
http://carstereohelp.com/stereoremovalNisMax3Str.htm
Old Dec 3, 2004 | 07:08 PM
Epacy's Avatar
Unsuccesful STL Coordinator
I was just about to email you something bout this 03on18s. But that link will work. Just pry up in one of the back corners of the automatic plate. Most of it is held down with snaps.
Old Dec 3, 2004 | 10:54 PM
03on18s's Avatar
awesome...thanks for all the info everybody
jmlee44
Oct 2, 2022 02:13 PM
BobTX10
Oct 7, 2015 08:43 AM
RealityCheck
Oct 2, 2015 06:34 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
jaydot901
Sep 29, 2015 01:18 PM
