Front Door Panel Removal
Old Dec 6, 2004 | 08:45 AM
Pri63's Avatar
Anyone know how to remove the front door panel, I took the window console out, the one screw towards the front of the door, and then tried to pull it off using the make shift handle provide on the bottom of the panel. Are there anymore screws and bolts, I need to take out or should I just pull the sh*t out of it?? Thanks.
Old Dec 6, 2004 | 09:14 AM
Matt_01SE_20th's Avatar
when i tried to do it the thing holding on was the handle/lock assembly. never figured how to get it off but i didnt need to for what i was doing.
Old Dec 6, 2004 | 09:44 AM
2K3MAX2NV's Avatar
"tse-tse fly"
there are clips surronding the whole door u need to separate one by one then get a spatula tool and slide it between the door and the panel to remove it there are also bolts that need to be removed as well
Old Dec 6, 2004 | 10:33 AM
mattattax's Avatar
There's gotta be a how to on this somewhere right?
Old Dec 6, 2004 | 10:39 AM
Maxima112's Avatar
Curb Rash Repair 100 a wheel
ok just pull the bottom hold with one quick tug, trust me, the trim surrounding the door handle will pop out but will not break, ive done it about 20 times. from there just go around teh whole door and take off the clips. oh yeah make sure you take out the step light to be safe.
oh yeah to be sure, make sure you take that screw out of the handle part, there is a little black circle cover over it, take a flat head and pop that out and then unscrew that screw,that is all.
vingodine
45
May 21, 2016 12:46 PM
Stelianos
Aug 19, 2015 02:07 PM
delerium75
Aug 19, 2015 11:08 AM
Abdelrhman
Aug 17, 2015 12:16 PM
kjm900r
Aug 5, 2015 07:14 AM
