cattman y-pipe got cali spec?
does it has cattman y-pipe for 2000 california spec now? 2 pieces?CA-spec Y-Pipe is a two-piece assembly composed of a rear section and a forward pre-cat which is attached directly to the forward exhaust manifold. anyone has a 2000 ca-spec with a cattman y-pipe?
this link will tell a detail...
http://www.greghome.com/Greg%27s%20G...S%20Y-Pipe.htm
cattman has had a cali spec y-pipe for a few years already. why don't you try their website????
www.cattman.com
its one piece not two. Only the stillen has a two piece y-pipe, the 2nd piece is for fed-spec or 95-98 maximas that require the extra extension
www.cattman.com
www.cattman.com
www.cattman.com
so, no y-pipe that include the front pre-cat that connect to the mainfold for the 00( cali spec)? ..since the whole set header is very expensive....maybe i'll try 02 sensor simulator to drive my car with no pre-cat...
sigh. you won't need o2 simulator for a y-pipe. try reading up more on the FAQ
the front precat is included into the front manifold, hence you won't need an extension piece. If you had a fed spec manifold, then you would need the extension because you won't have that front precat after the manifold
can u provide some pictures for me??? cus i saw the cattman site that show the part of the front y-pipe is straight..
the extension is a separate piece that attaches to the straight part leading upwards to the front manifold, why would you think the straight part is the extension? I've already told you cattman has two separate pipes for fed and cali spec, only stillen includes an extension piece
cattman fed spec - notice the extra piece welded on?
http://www.cattman.com/img/prod/dsc_...4%20y-pipe.jpg
stillen cali spec w/out extension piece - notice its just straight?
[QUOTE=Larrio]the extension is a separate piece that attaches to the straight part leading upwards to the front manifold, why would you think the straight part is the extension? I've already told you cattman has two separate pipes for fed and cali spec, only stillen includes an extension piece
http://www.greghome.com/images/Maxim...Cat_Lineup.jpg
"I've already told you cattman has two separate pipes for fed and cali spec"
My front pre-cat is not working either!!
ohh!!! cattman got two separate pipes for cali spec? good!! is it $350 free shipping?? got a pic for cattman cali spec.hehe? am i annoying?
wouldn't it occur to you that a cattman cali spec would look relatively the same as the stillen one without the front extension? that pic is included already and is also located on the cattman website
well ,i couldn't find it on cattman website..
www.cattman.com
engine/transmission - exhausts - 6th picture down the page
YG5/CA
1999-2001 Maxima/I30; CA/NLEV or “50-state” emissions specification ONLY.
Available Now!
YG5/CA
Available Now!
jmlee44
Oct 2, 2022 02:13 PM
KabirUTA13
19
Oct 17, 2015 02:15 AM
