A/T tranny 5th gen
Old Dec 7, 2004 | 02:08 PM
KabirUTA13's Avatar
IN IRAQ MAXIMA.ORG-ING :)
A/T tranny 5th gen
i wanna do my tranny oil change... would like some suggestions from you "maxima veterans"... n would it really matter where i get a gasket from ex. autozone, pep boys, or nissan store itself... and bout the damn tranny filter..... any special ones i shood seek for.... let me know wat kinda oil i shood use as well thanx guys
Old Dec 7, 2004 | 02:22 PM
Cutler's Avatar
Take it to the dealer and let them do the service. Shouldn't run more than $100 or so.....
Old Dec 7, 2004 | 02:34 PM
KabirUTA13's Avatar
one other question... would it shock my tranny if i used any tranny oil rather than the one it originally had say from reg to synthetic...?
Old Dec 7, 2004 | 03:02 PM
HotMax03's Avatar
Check the faqs out, there is a how to on flushing your tranny fluid.
Old Dec 7, 2004 | 03:05 PM
Cutler's Avatar
Amsoil ATF is what I recommend!
Old Dec 7, 2004 | 03:51 PM
R.I.P. Grandma's Avatar
You can also use Mobil 1 synthetic auto tranny fluid recommended by a lot of org members and can be easily purchased from autozone.
Old Dec 7, 2004 | 04:16 PM
mdloops's Avatar
Don't you have to Flush it and not drain it? I was always under the impression a machine needed to be used to flush out all of the loose particles. I would also NOT recommend just doing this as something to do. There are regular service intervals for that sort of thing for a reason. How many miles you got? Don't the AT need a friction modifier?
Old Dec 7, 2004 | 04:42 PM
When i got my Tranny flushed, i went to a mechanic who had a machine which sucks out all the old fluid and puts in the new one. Some people dont feel its neccessary to take out all of the fluid and just do a drain of about 8qts or so. Usually people wait at least 30k before flushing their tranny, but at the same point in time not everyone believes in flushing the tranny.
Old Dec 7, 2004 | 06:25 PM
upstatemax's Avatar
from what i remeber there is no gasket... it is a sealed unit and you need a machine to pull the rest of the fluid out... and yes you need to get the rest of the fluid out!!! the old fluid is filled with the s**t that causes problems and simply draining what is in the res. will only get like 20% of the fluid. my brother is a mechanic and HE told me to goto Nissan and use the proper machine...
dont be lazy and cheap with the maint. that is part of owning a 30+ thousand dollar car, they are expensive to maintain....
Old Dec 8, 2004 | 10:11 AM
schmatt's Avatar
I recently flushed my transmission. I also dropped the pan and cleaned it out. I had about 48k on my car. The fluid was burnt and the pan and magnets were very dirty. If you want to do it yourself, I would suggest completely cleaning it out. Just flushing the transmission does not clean all the crap out. It only removes the old fluid. When you put new fluid in, the detergents in it will wash all that crap back up into the transmission. This is why some high mileage trannies will fail after flushing the transmission. There is information on how exactly to do this in the Fluids & Lubricants forum. It is a sticky. Just remember to measure exactly what you remove, so you can replace it accurately. From what most people recommend, I used Amsoil ATF.
Also, there is a gasket. Mine happened not to have one when I dropped the pan, but you need to replace it anyway. So now it has a gasket. You will also need to replace the drain plug gasket and all 21 of the pan bolts. They have a special sealant on them that will break when you remove them. These pan bolt are supposed to be tightened to around 6ft-lbs. This is a very low torque, so make sure your torque wrench can go that low.
Old Dec 8, 2004 | 02:37 PM
KabirUTA13's Avatar
ok koo koo ... hmmm alot of ppl told me the 2001 max's don't have gasket... gess i gotta find out by my self then... thanx guys
MAXSE5SPD
Sep 17, 2022 04:00 AM
pktaske
May 6, 2016 07:49 AM
Violator
Sep 9, 2015 10:14 AM
pktaske
Sep 4, 2015 08:40 AM
Lowered_a33
Sep 1, 2015 07:49 PM
