G2 caliper paint
Old Dec 10, 2004 | 02:03 PM
Lontar1's Avatar
Puerto Rico-Maxima Lover
G2 caliper paint
CI'm going to paint my calipers today. Whenn I mix the reactor with paint , Do I have to paint all four at the same time or can I paint two first and then the other 2. Will the paint will get ruin if I do the other two tommorow,..?????
Old Dec 10, 2004 | 03:52 PM
FanaticMadMax's Avatar
I'm not sure I follow it, since the color should be the same, right? You can paint one at a time, but again, I'm no expert on what you said about mix with reactors. I hope you're not brewing some Uranium.
Old Dec 10, 2004 | 04:22 PM
MaxArt's Avatar
Do them all at once - or at least within and hour or two. The reactor sets the paint up as hard as epoxy in several hours. So have everything you want to paint ready to go before you mix, and then proceed. I have used the G2 on my GSR and the Max with great results, but you don't get a chance to touch up later.
Old Dec 10, 2004 | 07:33 PM
Lontar1's Avatar
So once is mixed there is no way to save dome for later... I mean the one in the can not the after is painted....
Thans for your response
Old Dec 10, 2004 | 08:26 PM
WildmanAL's Avatar
Read that yellow piece of paper they come with..... you have a four hour window before the paint dries to a big glob.
I had to paint all mine at the same time. It's not that bad. Just take your time and put on even thin coats. I had to put about 4 on before it was nicely coated.
Old Dec 10, 2004 | 08:33 PM
Lontar1's Avatar
I read the yellow paper ... I was planning on doing 2 today and two tommorow but I was concerned about the paint becming hard inside the can....
Old Dec 11, 2004 | 08:28 AM
WildmanAL's Avatar
Yeah even if you seal the paint back up in the can it still eventually becomes too thick.
REDinLV
Aug 15, 2024 12:30 AM
litch
123
Jan 4, 2024 07:01 PM
Apr 16, 2020 05:15 AM
imported_Nismo_max
Sep 21, 2015 07:24 PM
beerman1378
Sep 8, 2015 02:19 PM
