Since I didn't get an answer from the FAQ thread. . .
Old Dec 12, 2004 | 07:50 PM
5thgen2nr's Avatar
I will ask again, but here: Will my car fail emissions if I have a cali-spec y-pipe and a random technology high flow converter? Or do I need to have the OEM converter in place to pass cali-spec emissions? Kinda hoping it would fly with the RT converter so I don't have to shell out 500 or so bucks for a new OEM one
Old Dec 12, 2004 | 07:59 PM
BlkShadow01
gota have the OEM i think.. they are strict about all the pollution issues
Old Dec 12, 2004 | 09:30 PM
5thgen2nr's Avatar
Ahhhhh nooooooo...effing CARB sucks.
Old Dec 12, 2004 | 09:32 PM
Fezzik's Avatar
You should pass. Just make sure your car is warmed up really well before you go take the test.
Old Dec 12, 2004 | 09:57 PM
frankd121's Avatar
Yep, just as long the car is completely warmed up you should be fine. Make sure you don't have a check engine light or else they'll automatically fail you (they do that in NJ, i'm sure CA is similar). Once you hit the normal operating temperature, cylinder combustion temperatures will be high enough to give you a good full burn...
Old Dec 12, 2004 | 11:52 PM
5thgen2nr's Avatar
Okay...so the consensus is that I should pass, even with a higher flow catalytic converter and a CA-spec y-pipe? While I'm on the subject, where do they look and what do they look for in the visual inspection? I'm curious because I need to get my car smogged ASAP so my dad can boot me off his insurance.
Old Dec 13, 2004 | 09:21 AM
2k1seae's Avatar
In Oregon, they didn't do visual on mine. I don't have the hi-flow cat but the Y-pipe was no problem. Passed with flying colors. The car was fully warmed up.
D Mason
Jun 21, 2016 04:43 AM
doctorpullit
Mar 29, 2016 11:08 AM
leatherneck
Sep 30, 2015 09:16 PM
Sep 27, 2015 08:37 AM
