What is that d@mn squeaking coming from my front end?!
Old Dec 14, 2004 | 04:12 PM
Metal Maxima's Avatar
SHIFT_om nom nom nom
My Max is an '01 SE with 500xx miles on it. Everytime I hit a bump I hear a slight spueaking noise coming from the front end...anyone have any idea what it may be? Just the fact that it is there is driving me crazy!
Old Dec 14, 2004 | 04:44 PM
Smokie5s01's Avatar
I know this doesnt help you but I have the same noise comming from the front end. I only noticed it since I moved to RI. (the roads were I live now really bumpy) I think it might be the struts or maybe the springs but I havent had a chance to look at it. Hopefuly someone with some more experience will be able to help us with this problem. I also have 53xxx .........
Old Dec 14, 2004 | 05:53 PM
bumpdiddy bump...anyone else?
Old Dec 14, 2004 | 07:51 PM
LA02MAX's Avatar
i thought it was the hood the other day, because even when i close my door, it squeaks, and then i opened my hood and shook it a bit, and i heard the squeaking noise coming from the hinges, or w/e they are called...but i could be wrong, considering this is right next to the front suspension...but mine is just really sensitive, and squeaks even when i put just a little pressure on the hood, as well as when i go over any kind of bump
Old Dec 14, 2004 | 09:23 PM
stevay's Avatar
i used to have that slight squeak as did many other people, you said even when you shut the door...sounds familiar ...try lubing up the hood latch a little w/something...if dont have anything try a little dab of oil on it
Old Dec 14, 2004 | 09:44 PM
NYPD-Arnold's Avatar
Z
There's like this rubber coating that goes around a spring. When that coat gets loose or curls up, it creates that squeaking noise. I had the same problem. First, just press down on the front of your car to be certain that the noise is coming from the suspension. Take it to a shop who can lift the car and look underneath it and check the strut and spring.
JoshG
21
Sep 4, 2015 09:04 PM
Samedi
Aug 12, 2015 01:54 AM
follyburr
Aug 7, 2015 09:50 PM
laparka66
Aug 6, 2015 09:36 AM
BassAddictJ
Aug 4, 2015 11:38 AM
