TSB Question
Old Dec 14, 2004 | 06:29 PM
XGaSpAcHo
TSB Question
I've got a general question about TSBs. If I go to my dealer with the TSB in hand will they perform the service listed on it for free? I'm asking mainly because I want them to perform the TSB where they insert foam into the window channels so that wind noise is reduced at high speeds. Thanks in advance.
Old Dec 14, 2004 | 06:33 PM
SoonerFan's Avatar
Cletus
only if you are under warranty. for that it would have to be the bumper to bumper
Old Dec 14, 2004 | 08:38 PM
XGaSpAcHo
that's 3yr/36,000 miles right? if so then i am still covered under it. thanks man. i'm gonna try and set that up. does anyone know where i can find that TSB online to print out?
Old Dec 14, 2004 | 09:20 PM
stevay's Avatar
http://maxima.theowensfamily.com/tsb/
Old Dec 15, 2004 | 04:04 PM
XGaSpAcHo
which one is it? i dont see it.
Old Dec 15, 2004 | 04:43 PM
bladerunr's Avatar
I've never seen that TSB for a 2003. Go to Alldata.com for verification. Could you be referring to housecor's homemade fix for wind noise? That requires weatherstripping from Home Depot or Lowe's inserted into the space behind the factory rubber seal. Check the how-to sticky for more info.
Old Dec 15, 2004 | 05:12 PM
XGaSpAcHo
THAT'S where I saw it. Thanks man. It's this http://maxima.theowensfamily.com/tsb/NTB01-029.pdf but it says 2000 and 20001 model years.
Old Dec 15, 2004 | 05:53 PM
Larrio's Avatar
The Definitive AE Master
they will only perform the TSB is they can duplicate the problem at hand, which is where most owners testify why nissan service sucks.... because they never find the problem
and if you vehicle doesn't fall under the right years or VIN category, you do not qualify for the TSB
Old Dec 15, 2004 | 06:13 PM
XGaSpAcHo
mother f*%$@#s! yeah those guys are never too bright. looks like i'm SOL on this one. i'll have to do it myself i guess. lets just hope it's as easy as housecors instructions make it look. anything i should be careful of or look out for while doing it?
Old Dec 16, 2004 | 04:10 AM
jmal's Avatar
This is definitely a do it yourself job. If its the one I'm thinking of, where you put foam tape underneath the rubber molding around the windows, its no problem. Just roll your window down all the way and pull the rubber away from the door where its mounted...it should come right off and you can see the pinchweld where its mounted to. I think you just put some adhesive foam on the top of that pinchweld and mount the rubber back on, the rubber should cover the foam when its done. You'll see how easy it is once you pull off the rubber molding.
Housecor's site gives the size foam tape you'll need, as well as the instructions.
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
