HELP... Service Engine Light On
Old Dec 17, 2004 | 11:58 AM
2KmaximaSE's Avatar
It could be the psychology that my service engine light was on today for no reason and if felt like my car was shaking. Then it started flashing on me. What would cause the light to stay on and flash like this. I have never seen this before. Please help, thanks!
Old Dec 17, 2004 | 12:04 PM
Barc's Avatar
MAF? Coils? Bad fuel?
Old Dec 17, 2004 | 12:08 PM
nailz420's Avatar
many things could cause car to shake and SES to come on, but when it starts flashing then its something really serious that requires immediate attention. I wouldn even drive the car if that happend to me.
Old Dec 17, 2004 | 12:28 PM
2KmaximaSE's Avatar
I just called the dealership to get it in monday morning. They said it would be $50 to pull the codes if it wasn't something covered under warranty (failed part) I personally have never even seen this light before and was wondering how it tells if something is wrong or not? What was everyone else's experience?
Old Dec 17, 2004 | 12:32 PM
Metal Maxima's Avatar
SHIFT_om nom nom nom
If you have an autozone nearby, try them...they pull the codes, gratis
Old Dec 17, 2004 | 12:38 PM
2KmaximaSE's Avatar
thank you for that info... im going there as soon as I get off work today. I will let you know what the codes are.
Old Dec 17, 2004 | 01:29 PM
2KmaximaSE's Avatar
OK... I had 4 codes pulled off. They all said something about the ignition and the coil not firing. The guy at autozone said that one of my coils is not firing in one of my cylinders? He said that this would be a failed part and my warranty would cover it. He said it is burning oil and that if I drive it for a long distance I have a chance of ruining my converter? He said right now it is just burning up gas? How true is all of this?
Old Dec 17, 2004 | 05:51 PM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
the coils are typically covered 3yr/36k miles. if you have a good relationship with your dealer, you may get it under the powertrain up to 60k. if you have an extended warranty then use it. if not, i suggest purchasing all 6 coils and plugs if it is time and replacing yourself or having a shop do it. you can get all 6 coils for around 300 shipped. the main code you got was probably P1320, the others were most likely indicating which cylinder(s) that the misfiring is occuring in.
Old Dec 17, 2004 | 05:53 PM
tothamax01's Avatar
evil coils and their damn shinanigans.(sp?) im a lucky mine are fine
CorollaULEV
30
Aug 9, 2021 08:11 PM
Justinmc760
Aug 23, 2015 03:10 AM
maxinout93
Aug 20, 2015 02:17 AM
Flores94
Aug 11, 2015 12:53 PM
bassmann
Aug 3, 2015 07:53 PM
