data dot headlamp removal..
Just remove the headlamps by unbolting them. The recall, data dots update for the HID lamps on 5th gens relocates the ballest to a bracket thats bolted onto the frame rail. (Rendering the lights useless if their stolen) Your headlights will come out of the car normally just by taking out the two 10mm bolts on the radiator support and gently pulling the lights out. Then just unplug the lead from the back of the headlights that comes from the ballest on the bracket. (The ballest remains on the car) There's a plastic clip in the inner fender and a lower clip under the headlights that may hold the lights, pull or pry the lights gently and the clips should release.
the lights are being held to the data dot bracket with 3 bolts underneeth the light..and the bracket is held to the frame with 2 frame support bolts ...good luck getting them out without going from under the car.
Originally Posted by goldmaxNYC
actually you are wrong.
Nissan would not sell us the kit, can't figure out why, so we never reinstalled the recall in the customers car. I wasn't aware they were bolted from the bottom as well.
does anyone know what size bolts i can replace the tops ones with. i had the datadot recall done so it is nice that they are snugger from underneath but i want to but some torx bolts up top. anyone got a suggestion on what to use and where to get them from?
You know I think your right. The last headlight theft job we got at the body shop had the recall installed when the lights were ripped out. I do remember seeing a part of the plastic housing still connected to that bracket. Gezzz if thats the case, there gonna be a PITA to take out. Your probably going to have to take the splash shields off under the front end and go in from underneath to gain access to those bolts.
it took a bit of time ..but its worth it in my opinion i think.
if anyone took out their lights before . they know that ithe light is held in place by 2 bolts on top. and it has like a metal rod on the outer side of the light that snaps in into the fender.(hope you know what i am talking about )
well anyway.. this requeres for the front wheels to be taken off ..and the plastic on the inside of the fender to be taken out at least the front part...
what u do is take out that metal little piece from the headlight. then u can go from the inside of the fender and screw in a bolt right in place of that metal rod piece.
basically almost imposible to take out the lights.
the data dots themselves are numbers based off your vin # that are assigned to your headlights. if your lights get stolen and then turn up being sold on ebay or something , they can link the lights back to your car so you can press charges, and/or reclaim ownership. This is in addition to the metal bracket installed to supposedly make it harder to steal your lights and some dumb stickers that are supposed to deter thieves.
i never got my data dots, i maid the appt for the recall but over slept, and i just cleared the turn signal and did angel eyes, and i think i might get the data dots on now
Originally Posted by skierxx5556
alright since no one will tell me how to do this does anyone know if the dealer would tell me? if not then i may be willing to pay some one to clear my lights out.
AaronL
Nov 15, 2020 11:52 AM
mkaresh
Mar 12, 2018 06:48 PM
knight_yyz
Nov 1, 2015 01:34 PM
