HELP with taking out foglights.
Old Dec 18, 2004 | 05:29 PM
Sammzway's Avatar
Hey whats up guys, one of my friend needs help removing his foglights to change bulb, but it's not coming out. Anyone knows which screws to take out exactly to losen up the fog so it'll come out? Thanks.
Old Dec 18, 2004 | 07:13 PM
bladerunr's Avatar
What year is the car? If it's a 02-03 then check out the how-to sticky for housecor's write up.
Old Dec 18, 2004 | 07:18 PM
killer924007's Avatar
i got mine changed last week..it's 2k SE..just remove the screw from the bottom of the fog light..and then push it out..easy!!
Old Dec 18, 2004 | 08:42 PM
Progress's Avatar
It's business time.
1. Take off the screws and pop-tabs that are holding up the splash guard in close proximity to the foglight. Move the splash guard so you can see the housing of the foglight.
2. Once underneath, unscrew the bolt (10mm, I believe) that is under the foglight housing.
3. Detach the wire connector to the foglight with the help of a small to medium size flathead.
4. With one hand on the front of and one on the back of the housing push and pull it out of the hole. There are two prongs on the housing that need some nudging out from the back of the housing on the top.
5. Once out, just open it up and change the bulb.
If you need any more help, PM me.
Old Dec 18, 2004 | 09:08 PM
Sammzway's Avatar
PERFECT. Thanks a million, worked like a charm. God bless Maxima.org
tarun900
19
Dec 20, 2021 06:57 PM
TKHanson
Nov 24, 2018 01:39 AM
mpbclutch33
Dec 26, 2015 11:11 AM
