Hood swinging in the wind
Old Dec 19, 2004 | 07:14 AM
mdloops's Avatar
Anybody have this problem? I thought there was a TSB out. My hood moves quite a bit during highway speeds. If it is an easy fix or part I will probably do it myself. Any suggestions?
Mark
Old Dec 19, 2004 | 11:04 AM
Galo's Avatar
Maxima Pilot
Mark, for some reason, this is like really common on '02s and some '03s but strangely, not very common on 00s and 01 -mine's never done that.
And yes, there is a TSB and it involves re-bonding the sheet metal skin of the hood to the stamped steel cross-braces, installing a foam 'pack' on top of the headlights to minimize air coming in thru there and 'fluttering' and possibly other stuff that I ca'nt recall right now....
So yes, go see your friendly dealer and tell them it's their problem and post result!
Old Dec 20, 2004 | 05:34 AM
97Se5spd's Avatar
my 00' does that a little bit at highway speeds also not much though
Old Dec 20, 2004 | 06:15 AM
2k2kev's Avatar
It's chrome alright...
thank the owens family for hosting the TSBs
http://maxima.theowensfamily.com/tsb/
the one you want
http://maxima.theowensfamily.com/tsb/NTB02-005.pdf
Old Dec 20, 2004 | 07:39 AM
blackjackmark's Avatar
Would this be covered under some sort of factory recall situation? My car is well out of the factory warranty period (just bought it used) and have noticed this happening. I just had the MAF situation fixed (also a TSB) and had to pay out-of pocket for its repair.
Old Dec 20, 2004 | 08:19 AM
2k2kev's Avatar
It's not a recall.
Ask if they'll do it "good faith" or just say please. It costs them about $8 to do the fix so they might just do it hoping to keep a customer.
If they won't cover it, read the TSB and buy a bunch of JB Weld and weatherstripping and do it yourself.
Old Dec 20, 2004 | 08:22 AM
Bluesbrekr's Avatar
Doctorate in Detailing
Sometimes it can be fixed by raising the rubber hood stop on the driver's side. Sometimes the hood brace welds have come loose, but not on all maxes.
There is a way to adjust the entire hood latch assembly also (to have the hood close tighter). I think that info is in the FSM and may not be a part of the TSB.
Old Dec 20, 2004 | 10:07 AM
-Red-'s Avatar
As bad as it may sound, take some clear tape, and wrap it around the latch, it seems to have done the trick for me. You can probably wrap a very thin rubber hose around it. As I said, I know it sounds sh1tty, but it works.
Old Dec 20, 2004 | 05:32 PM
mdloops's Avatar
Thanks GALO! With all this new info I will look into it after the busy holidays. I will post results of how I fixed it when completed.
Merry X-Mas,
Mark
Miket2006
Mar 1, 2021 03:55 AM
AaronL
Aug 8, 2020 10:31 AM
howardis
Dec 11, 2019 06:10 PM
bigdogsteve
Jan 31, 2018 04:18 PM
leatherneck
Sep 30, 2015 09:16 PM
