2002 computer with non-oem radio
Old Dec 21, 2004 | 01:45 PM
dr_redonkulous's Avatar
i can't find the DIY for this thing anywhere. the computer that is controlled by the steering wheel (temperature, distance until empty, mpg...) can be bypassed by grounding a wire and taping the other end off. i remember seeing this posting a month ago, but can't find it. anyone know which wire to splice for this computer to work? thanks
Old Dec 21, 2004 | 02:22 PM
026speedmax's Avatar
i didnt know this could be done, i need the info also. Thank you in advance.
Old Dec 21, 2004 | 02:34 PM
PoLo's Avatar
2-Wheelin it...
open up center console. look behind radio. find a bunch of harnesses. specifically 2 harnesses that contain a brown wire with a white stripe. 1 is thick and should actually be attached to the current radio as that wire controls the left speaker negative terminal. the OTHER harness which would not be connected to anything contains a THIN brown wire with white stripe as well. cut wire, tap to ground, done...you're welcome.
Old Dec 21, 2004 | 02:41 PM
nice. you're the man
Old Dec 21, 2004 | 02:50 PM
gabe22's Avatar
does that allow you to use the steering controls with an aftermarket HU?
Old Dec 21, 2004 | 11:17 PM
imxelite's Avatar
Correct just the trip buttons though. If you want the volume your going to have to buy a adapter piece for that.
gavin68
Sep 18, 2021 12:36 PM
09maxshawn11
Sep 30, 2015 10:28 AM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
Max Nu-BE
Sep 28, 2015 10:25 AM
