When replacing brakes, should I..........
Old Dec 23, 2004 | 04:51 AM
nikemike's Avatar
also have the rotors turned? I have 74K that is mostly highway miles with low braking but they are starting to make some noise. I also do not get any shimming when braking, so could I just throw on new pads and turn/replace them next time?
Old Dec 23, 2004 | 05:07 AM
Y2KMaxGXE-R's Avatar
dont turn them, they will last longer.
Old Dec 23, 2004 | 05:21 AM
Nyc2kMax's Avatar
YEH just change the pads ... Only change the rotors if you are getting shimming when braking...... you can try Raybestos Quiet Stop (QS) pads to stop the noise.
Old Dec 23, 2004 | 07:05 AM
Galo's Avatar
Maxima Pilot
Sorry, both these posts/answers above are wrong.....you should always turn your rotors when u change pads, for two reasors:
First, not only does turning them make the rotor face perfectly smooth and flat, removes all surface grooves, etc, but it also creates the right surface finish to allow the new pads to 'break in' properly.
Second, all pads transfer some amount of pad material to the rotor face itself. Turning the rotors removes a sufficiently small amount of material from the rotor's face that it's 'clean' of the old pad compound which tranferred over during high-heat conditions.
If you are not shimmying when braking, it means only a few (two, three) thousands of an inch need to be cut off the rotors, no big deal for any rotor longevity issue.
I know brakes. If in doubt, look here. I ws the prototype car for this brake kit and all the measurement for rotor hat offsets, etc were done by moi.
http://www.cardomain.com/id/elgalo
Old Dec 23, 2004 | 07:56 AM
Nissan SE-R's Avatar
Don't turn the rotors unless they are really grooved. If they are smooth you can just keep using them. You can always just give them a light cross hatch pattern with sand paper if you want to be really thorough. In general, almost no one turns rotors anymore. If they are gone enough to need to be resurfaced, people usually replace them. Turning them is pretty old school.
Old Dec 23, 2004 | 08:05 AM
Zero Deuce SE's Avatar
It is not always required to turn rotors. If they are not deeply grooved, the pads will do the resurfacing within a couple hundred miles of driving with no panic stop type braking. I do a few brake jobs where I work and also do my own when needed. I only have them turned if I see and feel deep grooves in them. I don't know of any problems that surfaced from not having rotors turned that were in good shape.
Matt93SE
May 24, 2019 02:58 PM
rbuswell
Nov 17, 2016 04:54 AM
vingodine
45
May 21, 2016 12:46 PM
seesole
Aug 26, 2015 11:22 AM
Samedi
Aug 13, 2015 04:05 PM
