Hella Horn Question
Old Dec 25, 2004 | 10:06 AM
Jinro's Avatar
Hella Horn Question
Hi, I was just wondering where you guys buy the Hella Horn. How much does it cost? Can the install be done by an amateur like me or should I take it to a shop? Thanks a lot!
Old Dec 25, 2004 | 10:13 AM
aliti19's Avatar
Maxima addiction cured w/ the GS pill
It's plug and play. Pretty easy to install. Should cost around $60. Depends where you get it from. There might still be a group deal on it. I gotta get one too. Our horns sound soooo wimpy.
Old Dec 25, 2004 | 11:33 AM
03on18s's Avatar
i have them on my car....super easy install, took 10 mins at the most. i don't remember where i got them, but i know they were $45 shipped.
Old Dec 25, 2004 | 02:41 PM
PO-POMAX2K's Avatar
If yours are the 118db's you got a good deal. I missed the group deal for $60 shipped and had to order mine from http.www.autobarn.com for $64 + shipping.
Old Dec 25, 2004 | 02:45 PM
03on18s's Avatar
not sure what dB mine are....but i know they are significantly louder and deeper than the stock horns. i'm happy with them.
Old Dec 25, 2004 | 04:10 PM
turbo_gg's Avatar
I got mine on the group deal for $60 shipped. And yes, they are WAY louder than stock!! They are very easy to install, they mount to the stock horn positions. They have to be individually grounded, but that is it. Anyone can put these on succesfully.
Old Dec 25, 2004 | 05:22 PM
Jinro's Avatar
thanks for all the replies...whats a db anyway?
Old Dec 25, 2004 | 05:33 PM
imxelite's Avatar
db=decibel .......
Old Dec 25, 2004 | 05:40 PM
03on18s's Avatar
a dB is a somewhat meaningless term, it refers to no certain level in particular, so it is referenced to whatever the manufacturer chooses, but since no one actually knows what that reference level is, it is very hard to compare a dB level to another companies dB level. however, if you have dBm (which references to 1mW), for example, that will give a clearer picture of the level of the sound. If these horns produced a level of 118dBm, then one could reference that to 1mW and find out the actual power level that this dB level is associated with. hey, you asked and i'm an audio engineer and a electrical engineer! haha
Old Dec 25, 2004 | 05:49 PM
bladerunr's Avatar
How do the Hella type horns effect the remote entry lock signal of one short horn beep? I assume the beep is louder, but how much?
Old Dec 25, 2004 | 05:52 PM
03on18s's Avatar
it's actually not...that's one thing that sucks. the car doesn't send out as much voltage to the horn when you lock the car as it does when you're driving and lay on the horn. the horns get exactly 12V across them when you honk the horn, but when the doors lock and the horn beeps, it only peaks at 0.9V. this voltage may have been enough to get a decent beep out of the stock horns, but it is not enough voltage for the hellas. so it is slightly quieter than stock, but i like it....that way not everyone knows i'm walking away from my car haha
Old Dec 25, 2004 | 05:53 PM
03on18s's Avatar
one thing - i DID NOT use the relay in my setup. i would assume that if you used the relay, this problem would be slightly lessened.
Old Dec 25, 2004 | 06:27 PM
PO-POMAX2K's Avatar
Some good info there, I didn't use the relays either. Hella has two sets of the same horns, 113db and 118 there is a price difference and a different Manufacture point as well. You will definitely be pleased w/ the sound.
Old Dec 26, 2004 | 03:58 AM
Bluesbrekr's Avatar
Doctorate in Detailing
Look for the ones made in Germany. That's what I have. There are some made in India now.
Unlike a lot of people, I used the relay. Takes a bit more time to install, but I wanted to get the full potoential from these horns. I can't say if there is any db difference using the relay, cause I never hooked them up without it. As mentioned above, make sure you have each horn well grounded....if you don't, they won't make a sound.
Old Dec 26, 2004 | 07:12 AM
ZIPPIN's Avatar
Mauja He Mauja
yup. look for the germany made ones. and move the one in the engine bay to the front...they will be louder that way
Old Dec 26, 2004 | 07:24 AM
Bluesbrekr's Avatar
For those of us with 2k2/2k3, both horns are already facing forward right behind the grille. The 2k/2k1 can be re-located as Zippin mentions.
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
