changing Tranny oil in the morning
Old Dec 30, 2004 | 09:34 PM
Lontar1's Avatar
Puerto Rico-Maxima Lover
what hose from the radiator do I need to remove. I'm doing the full flush w/o droping the pan. Can someone post a pic so I can do this project in the morning. Thanks
Old Dec 31, 2004 | 04:48 AM
NYC TAR's Avatar
for the 2k2 ( it should be the same) it the short / bent hose,
Old Dec 31, 2004 | 07:03 AM
Lontar1's Avatar
I'm holiding off on this... I'm ordering the pan gasket and bolts to do it right...........
Old Jan 7, 2005 | 09:33 AM
Lontar1's Avatar
I got all the parts... so this weekend the car is having a transmission oil replacement....... hopefully everything will go ok... and no trannu slipping after is done....
Old Jan 7, 2005 | 09:36 AM
Bl_asd's Avatar
will it cause tranny to slip after changing the oil? i want to take my car to dealers...i live in orlando too.
Old Jan 7, 2005 | 09:57 AM
Santa29's Avatar
Hey Lontar1, you mind taking some pictures and doing a small DIY step by step when you doing it this weekend, I want to do it also but am confused as to what to do. I read about it but some pictures would be nice, How bolts do you need, and i think its 10 quarts of ATF right? also could you also take a picture of which hose to unplug to do the flush, Thanks
Old Jan 7, 2005 | 12:47 PM
Lontar1's Avatar
Not aproblem but there is a HOW to on the HOW to section... But I'll do the write up with pics...... starting tonigh....
Old Jan 7, 2005 | 02:40 PM
schmatt's Avatar
I did this a couple of months ago. Make sure you measure what initially gets drained from the pan. Mine ended up draining around 6.5qts just out of the pan. In the sticky under the fluids and lube forum, it said you would get around 4.5qts out. Also, you will need exactly 21 pan bolts. These pan bolts only get torqued to 6 ft-lbs. This is a pretty low torque. Pretty simple, just a little messy. My pan was filthy and the fluid was burnt, I wouldn't doubt it if yours is too. You'll be glad you did it when you get done. The hose you need to disconnect, you can't miss it. It's short hose that goes from the driver's side bottom of the radiator to the tranny. MAKE SURE YOU DISCONNECT IT FROM THE TRANNY SIDE. Try and have someone helping out. The hose is a pain to try and aim into a container.
I didn't see any real improvement in the shifting. But I'm still trying to convince my dealer there is a problem. I still have a delayed downshift from 2nd to 1st when I floor it. Even if it doesn't improve this, it will improve the life of the tranny.
Old Jan 7, 2005 | 03:00 PM
E55AMG2's Avatar
Wat
Lontar, you will need ~12 quarts of fluid to do the proper flush.
Old Jan 7, 2005 | 04:23 PM
Lontar1's Avatar
Do I really need the bolts? I spoke to DaveB and he told that it is not required... If I need it I'll buy them locally. I thought i needed only 10... I'll buy two more in the morning... I'm draining that sucker tonight.... and will gfo from there.... I wont need my car for the weekend so I can wait......
Old Jan 7, 2005 | 04:25 PM
E55AMG2's Avatar
Wat
The extra 2 are to make sure the fluid is absolutely clean. Nissans Technicians do it this way
Old Jan 7, 2005 | 05:36 PM
Lontar1's Avatar
Nissan doesn't even drop the pan when they do their "Flush"
I'll buy the bolts in the morning and the 2 extra q of oil....
Thanks guys.. wish me luck
Old Jan 7, 2005 | 05:39 PM
E55AMG2's Avatar
Wat
My dealer does....
Old Jan 7, 2005 | 06:14 PM
Lontar1's Avatar
which one in Florida.. don't tell me Universal Nissan cause tthey suck..... in my opinion... but I'll buy the 2 q in the morning plus the bolts.... thanks man.....
Old Jan 7, 2005 | 07:57 PM
2002 Maxima SE's Avatar
Good luck Lontar. It's very simple to do. After you get the hose off and hooked up to the extra hose and into the drain pan, thats really all you need. You can hook up the return to your fresh oil, but I found it's easier (and less messy) to just pump out 2 quarts and put 2 quarts back in via the dipstick. Hope that helps.
Old Jan 8, 2005 | 06:30 AM
Lontar1's Avatar
Ok I started doing the Tranny oil change... Damn.. the oil is dirty BIG TIME and smell like crap..... I'm taking pics and will do a write up on it .... so expect the write up and pics on Sunday............
Old Jan 8, 2005 | 09:17 AM
schmatt's Avatar
The reason why you need new tranny pan bolts is that there is a sealant attached to the bolts. When you remove the old ones, this seal is broken on those bolts. The factory service manual even states to replace the bolts when you drop the pan. Can you reuse them, yes. But why not get new ones when they're so cheap. Just a little extra piece of mind to make sure your tranny doesn't develop a leak. And yes, there are 21 bolts holding the pan in place.
Old Jan 8, 2005 | 09:19 AM
SoonerFan's Avatar
Cletus
you should install a tranny cooler while you are at it. i installed one the last time i did a fluid flush.
Old Jan 8, 2005 | 04:07 PM
ZIPPIN's Avatar
Mauja He Mauja
you have posted that you already did the write-up. all i see is 1 pic ?????
Old Jan 8, 2005 | 04:11 PM
Lontar1's Avatar
I'll update the sig... right now..
Mar 12, 2020 12:06 AM
ag90fox
Sep 9, 2015 12:22 PM
pktaske
Sep 4, 2015 08:40 AM
sdotcarter
Sep 2, 2015 09:53 PM
Lowered_a33
Sep 1, 2015 07:49 PM
