HOW TO: Brighten your instrument cluster *PICS*
Old Jan 1, 2005 | 02:02 PM
Metal Maxima's Avatar
SHIFT_om nom nom nom
As promised, here is the write-up for brightening your instrument cluster. It's ALOT brighter than the pics show them as being. Enjoy!
http://www.cardomain.com/memberpage/758364/2
Old Jan 1, 2005 | 02:03 PM
Oh, and yes I know the SES light is on. I have yet to get that looked at
Should this be made a sticky? Oh, and if any mods are reading this, could I have my avatar enabled? Thanks!!!
Old Jan 1, 2005 | 02:07 PM
irish44j's Avatar
retired moderator
nice job, man!!!
finally someone actually does it and it looks good!
Old Jan 1, 2005 | 02:09 PM
irish44j's Avatar
retired moderator
by the way, it the lighting completely even, in person? Looks like there are a few kinda bright spots in the pics, but maybe that's the camera!
Old Jan 1, 2005 | 02:15 PM
Thanks! The left side looks fine in person, the camera does skew the lighting a bit. I do need to aim the righthand side a bit more though, I just need to back the bulb out a touch.
Old Jan 1, 2005 | 02:22 PM
Bluesbrekr's Avatar
Doctorate in Detailing
Looks great! And seems fairly simple to do. If I ever get my gauge rings ordered, I'd swap out the bulbs at the same time.
Old Jan 1, 2005 | 02:46 PM
irish44j's Avatar
retired moderator
The only question I have is...you write:
Use the exposed wire to determine your mounting depth
how do you actually secure the new bulb in whatever depth/aim position you want it in??
Old Jan 1, 2005 | 03:00 PM
Bluesbrekr's Avatar
I bet he was figuring the stiffness of the wire would hold it in place. I bet there would be some way to shim the new bulb in the hole. Or maybe make the new hole just the size of the new bulb so it would hold itself?
Old Jan 1, 2005 | 03:11 PM
The wires used as contact extensions are used to change the mounting depth. The deeper you want the buls in the hole, the more slack you give to the wire. Vice-versa, to mount the bulb further out you would have less wire to solder to the circutboard. Oh and 5 on the stiffness comment - they provide all the strength you would need and more!
Old Jan 1, 2005 | 03:12 PM
Yes, you could probably take a caulk or some type of modable putty to mount the bulb in place.
Old Jan 1, 2005 | 03:13 PM
ICELANDIC MAX's Avatar
Old Jan 1, 2005 | 03:24 PM
mjg's Avatar
mjg
pretty cool writeup. Wish i tried somethign like this when i did my chrome gauge rings.
Old Jan 1, 2005 | 04:11 PM
ZIPPIN's Avatar
Mauja He Mauja
very helpful directions..what is the sand paper for??
Old Jan 1, 2005 | 04:23 PM
PO-POMAX2K's Avatar
Very nice job on the write-up too bad I'm still scared to try it. Congrats.
Old Jan 1, 2005 | 07:46 PM
Fezzik's Avatar
Hey. Great Write-up. Do you by chance any before and after pics. This would be great for comparison.
Old Jan 1, 2005 | 08:13 PM
F23A4's Avatar
I'll just go with the Ebay specials.
Old Jan 2, 2005 | 03:57 AM
Bluesbrekr's Avatar
Hey Busta - I'm assuming the brightness control for the dash lights still works after this mod, right?
Also, how's the balance between the gauge lights and everything else? If you turn the gauge lights down how bright are the rest of the lights?
Old Jan 2, 2005 | 09:06 AM
I adjusted the bulbs last night and will post the pictures in my cardomain site tonight...looks PERFECT now!!!!!!!!
The sandpaper is used to scuff up the electrical contacts of the 194 bulb. If you don't scuff the ends up, the solder will not adhere to the ends of the bulb contacts. Additionally, that is also why I twisted the ends of the speaker wire around the contacts.
Yep, sure does!
I did a complete LED swap-out on the window controls and HVAC unit...so it blends in quite nicley!
Old Jan 2, 2005 | 09:42 AM
jrod1014's Avatar
looks like a great job... congrats... i'll probably try this when i have a spare cluster
Max139617
Sep 6, 2015 06:02 PM
